Old 12-23-2012, 08:30 AM
ChuckDriver's Avatar
ChuckDriver ChuckDriver is offline
Looking forward to another great build!
JJ
My 1957 project:
http://67-72chevytrucks.com/vboard/s...d.php?t=334552
Old 12-23-2012, 08:42 AM
NvrDun71 NvrDun71 is offline
Mark do you use a stock off the shelf GM clutch master cylinder? From your pics it looks like an OE 02' F-Body setup. If so have you found any issues with high RPM shifts? Also do you typically just incorporate a clutch pedal stop into the upper pedal bracket? Appreciate your insight on this.
71' Nova - LY6, T56
Old 12-23-2012, 08:46 AM
Sieg's Avatar
Sieg Sieg is offline
Awesome Mark!
Thanks for keeping the fire lit and continuing to raise the bar. The inspiration your projects instill in people around the globe is noteworthy.
Old 12-23-2012, 08:49 AM
Ron in SoCal's Avatar
Lots of great ideas Mark! Thanks for posting...
Ron in SoCal
69 Camaro in progress
Old 12-23-2012, 09:08 AM
Track Junky's Avatar
Thanks for posting Mark. I have to ask.......why is it you continue to go with a four link in the rear as opposed to a 3 link with a watts link?
Gaetano Cosentino
Old 12-23-2012, 09:14 AM
Stielow's Avatar
Stielow Stielow is offline
It works, packages well and I like it
If it ain't broke don't fix it. The DSE deal works great. I'm putting a lot of power to it and the only thing I change from the DSE set is a couple reinforcements and a brace to the pan hard bar on the body side.
On paper the 3 link with a watts link is better.... But the DSE stuff works for me.
Mark
Old 12-23-2012, 09:17 AM
Stielow's Avatar
I'm using the DSE adaptor and the 2002 F-car apply system. With the LS9 clutch and a 7000 RPM shift it works fine. I'm at the limit of the LS9 clutch. I would not use it for drag racing.
I will put the pedal stop on the fire wall.
Mark
Old 12-23-2012, 09:18 AM
frankv11's Avatar
frankv11 frankv11 is offline
another great car on its way
Old 12-23-2012, 09:39 AM
mad68rs mad68rs is offline
Sweet! Just in time for Christmas!
Stielow's Avatar
Originally Posted by SIXX View Post
Camaro XV sounds like the perfect project name.. Mark could you tell a big difference on drive feel on Camaro X with its stock subframe and a DSE sub on Red Devil besides able to run a wider wheel? Looking forward to seeing your new project come together.. Happy Holidays Mark!!
There are a lot of great things with the DSE sub-frame.
Great structural feel - Red Devil had no forward bars.
Header clearance with the rack over the stock '69 steering box
Corvette knuckles brakes and ABS sensors
Wider front tires and good turning radius
Sorted set up - I use the as received springs and bars from DSE
Camaro X worked great with the stock sub. The headers were the biggest pain.
I have driven other front sub frames but in my opinion DSE has the best structural feel.
Mark
