Old 01-15-2013, 08:55 PM
Datsbad's Avatar
Datsbad Datsbad is offline
So I take it a DSE unit won't work? I bought the subframe new from a friend, who got it straight from Wayne. I think I had to buy the rack from Wayne, no idea where he was getting them modded, if that is indeed the case.
no DSE unit is different slightly. a SN95 rack has the right dimensions to bolt up. Have to change out the ends or disassemble the rack and modify. Not a big deal . Theres more to the story . Customer has never driven this car 1 miles . Insisit's it has PS steering but then says were doing a DSE front frame and LS with Quadarlink very soon to it.....Just a waste of money .
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 01-15-2013, 08:59 PM
camcojb camcojb is offline
well, sounds like he has plenty of money, and as long as he's willing to pay twice for it, then that's good for you.
Old 01-15-2013, 09:03 PM
Datsbad's Avatar
yeah ... but I end hearing it later even after he made the decision... know what I mean .
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 01-15-2013, 09:32 PM
Geez --- Too bad I sold the one I had hanging in the shed from the ceiling! It had P/S....
Old 01-15-2013, 11:58 PM
Vince@Meanstreets's Avatar
Geebus Weld, you got sheet all over the place. LOL
Hey Jason, I have an early early Wayne frame, Might even be a Rasmusen frame. I found that it was different, a bit wider and we found that they used a mid 90's Caravan outer tie rod to make it work. Thst might help you out.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 01-16-2013, 04:20 AM
Rick D's Avatar
Rick D Rick D is offline
Leave it to you Greg, only you would have a sub frame hanging from the ceiling!
Rick
Old 01-16-2013, 08:12 AM
I'm a "newbie" to this whole car hot rodding thing....
Old 01-16-2013, 11:46 AM
Z06vette's Avatar
Z06vette Z06vette is offline
I have an early wayne due frame w/C4 suspension/C5brakes. Its been a while, but when I was trying to find out what rack was on it the match was 93 cobra mustang and/or 94/95 cobra. I dont know if this will help you or not but I figured it couldnt hurt. The LS1 pump has too must assist on this rack for my liking. Its great for autocross, but on open track w/higher speeds it will be too twitchy for me. Right now Im running a smaller restricter in the pump,which helps, but I will evemtually have the rack revalved.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 01-16-2013, 12:12 PM
That's a problem with running a GM pump and a Ford rack.... There is a valve replacement for that on the high pressure side of the pump. But I agree = it's close but not perfect.
Old 01-17-2013, 07:13 PM
coolwelder62's Avatar
I am almost sure you could a DSE (24.5)rack(The DSE unit use's 9/16 mounting bolt's on 15.5"center's).Might have to use some .750 O.D X .058 wall tube to make a new thur mounting sleeve.The DSE unit are revalved for GM pump PSI.
