Old 05-22-2006, 07:42 PM
comp-spec's Avatar
Originally Posted by Datsbad
I have hydroboost and the new 6 piston baers front and back with a 1-1/8 bore . My pedal feels perfect !
I have to run a manual brake set up (space is tight) trying to get it done before powertour.
Old 05-22-2006, 07:47 PM
Datsbad's Avatar
Datsbad Datsbad is offline
try a smaler bore then try a larger one . shouldnt be much work . but i assume you have it under the dash ? then that might be a pain in the a$$ to keep switching.
try calling Paul at Hydratech , I bet he would help .
If you want a larger one try a 78-81 vette, thats a 1-1/8
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 05-22-2006, 07:56 PM
comp-spec's Avatar
Luckly its not to bad to change. I've change it a few times try diff masters it seems the smaller bore the better
Old 05-22-2006, 08:00 PM
Datsbad's Avatar
well , good luck . I know that hard pedal feel sucks !
hey do you have a pony tail ? i think i saw you at hershey
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 05-22-2006, 08:02 PM
comp-spec's Avatar
Ya I have a pony tail and my buddy was bald
I had the car at hershy
Old 05-22-2006, 08:04 PM
Datsbad's Avatar
I was going to stop and talk , but you were busy .
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 05-22-2006, 08:05 PM
comp-spec's Avatar
Should have stopped
Old 05-22-2006, 08:07 PM
comp-spec's Avatar
Sounds like your going to make powertour
