Old 05-16-2006, 05:52 PM
comp-spec's Avatar
Default which master are u using
Im running wilwood 6 piston front and wilwood rears. What master are u using (non power). Trying to get rid of a hard pedal.Brakes are up under the dash so space is tight.
Old 05-19-2006, 06:50 AM
TravisB TravisB is offline
I have one of wilwoods pedal kits.....for my car! Do you need the bore size???
Kenny Davis Hot Rods
Old 05-19-2006, 06:20 PM
comp-spec's Avatar
Trivis
Im running a wilwood now 1in bore and the petal is too hard ,going to try a 7/8 and see if its any better. Just wondering what every one is using with (non power) big brakes .
Old 05-21-2006, 11:14 AM
awr68's Avatar
awr68 awr68 is offline
I have the Wilwood 6 piston (front) and 4 piston (rear) set and was told to use a 1 1/8" bore for non-power, so I bought a late model S10 master, hope it works!!
Tony
'68 Camaro
Old 05-22-2006, 12:47 PM
comp-spec's Avatar
awr68
I was told to use a smaller bore (7/8), who told u to use a 1 1/8 ??
Old 05-22-2006, 01:17 PM
4mm 4mm is offline
Use a smaller bore for lighter pedal feel. I have a 7/8 on six piston wilwood fronts and the pedal is still very hard to push.
Old 05-22-2006, 02:37 PM
comp-spec's Avatar
Thats what I was told too.
Old 05-22-2006, 05:59 PM
awr68's Avatar
Originally Posted by comp-spec
awr68
It was either Wilwood or Precision...pretty sure it was Wilwood though....
Does the stroke have anything to do with it??? (Allan leave that one alone!!)
Tony
'68 Camaro
Old 05-22-2006, 06:22 PM
comp-spec's Avatar
Ya there diff pedal ratios
I talked to wilwood and they said smaller bore?
Im going to check psi at the caliper.
Old 05-22-2006, 07:11 PM
Datsbad's Avatar
Datsbad Datsbad is offline
I have hydroboost and the new 6 piston baers front and back with a 1-1/8 bore . My pedal feels perfect !
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
