Old 01-05-2016, 05:04 PM
andrewb70's Avatar
Originally Posted by Vega$69 View Post
I like the Holley set up better then the GM. Check out Jegs.
You can use either water pump.
I have a brand ne LS3 WP if interested. With gaskets and Tstat housing
The best part about the Holley alternator bracket is that it uses the less expensive truck style alternator (the Vette is unique and expensive...duh!) but puts it in the same place as the C5/C6...Plus, the Holley can be used in the Y, F, or truck spaced balancer.
Andrew
Old 01-05-2016, 08:02 PM
glassman's Avatar
glassman glassman is offline
Andrew
Cept in my 2nd gen, keith had too notch the fender wells as the vette kit is low and wide, unlike the other kits that are tight and high. Which is why i ditched the Holley stuff, good fit and plenty of clearance, just had to notch the fenderwells....i ended up with wegner, very happy
Mike
Old 01-31-2016, 12:36 AM
marathonboats marathonboats is offline
Banned
I agree that The best part about the Holley alternator bracket is that it uses the less expensive truck style alternator
