Old 06-23-2014, 05:15 PM
fillpot fillpot is offline
Default Time to change accessories
Guy's got a ls2 out of a trailblazer in my 69 Camaro and have been using the stock accessories for a while now time for a change, one of the main reasons is the p/s resivor is so close to rubbing a upper control arm bolt that I can't stand it plus just put on a fast 92mm intake and the alternator just looks out of place and want to move it over, the a/c will be fine because the subframe is already notched from when it had a lt1 in it, any insight thinking about the holley or kwik brackets. THANKS!
Old 06-23-2014, 07:13 PM
hifi875's Avatar
hifi875 hifi875 is offline
Use c5/6 vette
69 camaro
03 z06
90 mustang coupe
1950 international l110
1993 mustang gt
Old 06-23-2014, 07:45 PM
130fe 130fe is offline
Thumbs up
Originally Posted by hifi875 View Post
Use c5/6 vette
X2, this is the best deal out there for new GM stuff http://paceperformance.com/i-6485405...7-engines.html Just add a water pump and crank pulley and you are set.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 06-24-2014, 08:59 AM
gray776's Avatar
gray776 gray776 is offline
Depending on your setback, the C5/6 setup will have the PS pulley very close to upper CA bolt as well.
Depending on your budget, from what I have seen, the Wegner drive is awesome.
Old 06-24-2014, 10:04 AM
Gabe @ G-Rodz Gabe @ G-Rodz is offline
C5/C6 accersories are the best bang for your money. Other than that go for the Vintage Air LS Front Runner set up. That set up is absolutely BEAUTIFUL!!
Old 06-24-2014, 11:14 AM
Thanks for the replies, was wondering could I just change the reservoir by chance!
BTW, Chris do you miss this muggy deep south air!
Old 06-24-2014, 01:32 PM
Thumbs up
Getting used to the weather, the difference between the dry heat and humidity are kind of a draw- both of them suck in their own ways. I definitely enjoy living in Vegas much more than Crestucky (Crestview) LOL.
Chris
1968 Camaro SS
LS3/T56
Old 01-01-2016, 01:27 AM
Nativefx Nativefx is offline
So can anyone tell me which water pump I should be sourcing to use with this accessory drive from Pace Performance? From my research, I see they have 2 different LS3 water pumps and I'm trying to figure out which one i need. If anyone has an actual part # that would be great! thanks.
Old 01-01-2016, 06:04 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I like the Holley set up better then the GM. Check out Jegs.
You can use either water pump.
I have a brand ne LS3 WP if interested. With gaskets and Tstat housing
Old 01-01-2016, 08:01 PM
I like the Holley stuff as well and am using the A/C bracket setup from them with the C5/C6 accy setup. Id be interested in your water pump, gaskets and Tstat so let me know what your looking to get out of it. I just want to make sure that I can get the right hose and don't have any interference issues, so wasn't sure if one pump was better than the other.
