Old 07-03-2014, 07:47 AM
71RS/SS396's Avatar
Originally Posted by wiedemab View Post
Yikes -- that sounds wicked....
- - I have a Nova that you could store the old engine in!
I think you'll have to fight Deb for the old engine.... there's already some negotiating (threats) going on about that.
Old 07-03-2014, 08:03 AM
wiedemab's Avatar
wiedemab wiedemab is offline
Hell, I'd take her old engine.... beggars can't be choosers, right!
All kidding aside, you with a new/better motor and her with your old motor...... Look out - -- the McGiltons are stepping it up yet again!
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 07-15-2014, 03:37 PM
71RS/SS396's Avatar
Here's where we are now, may do another cam test.
Old 07-15-2014, 04:16 PM
Flash68's Avatar
Flash68 Flash68 is offline
hydraulic roller to 7800?
pretty bad ass there Tim
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-15-2014, 04:58 PM
71RS/SS396's Avatar
We've had LS hyd rollers up to 8,500! Fwiw those numbers are with all the accessories on it and the water at 180*
Old 07-15-2014, 05:10 PM
Flash68's Avatar
I was thinking more of the longevity of it going that high.
2014 4 tap Keezer
Old 07-15-2014, 07:42 PM
Ron in SoCal's Avatar
Tim the motor is bad ass. My iPhone showed the dyno sheet upside down and my kids were looking at me funny while reading it all contortioned
Can you comment on valve float issues on a hyd roller turning 8500? How do you and Kurt get around it?
Ron in SoCal
69 Camaro in progress
Old 07-16-2014, 02:24 AM
71RS/SS396's Avatar
So far we haven't seen them be any worse than a solid for durability. I plan to maintain them as I would a solid, the lifters and springs will get replaced every season for insurance.
We are using a stud girdle that we make on the rockers , short travel lifters, and I also think how Kurt goes about setting up the valve springs helps as well, Kurt is a guru with these engines and knows so many tricks that are unconventional. The block also has a raised cam which translates to shorter pushrods and thus less deflection.
Old 07-16-2014, 09:50 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
It reminds me of my engine, but way nicer.
I'm using a 4.185" bore and 4.125" stroke with RHS LS7 heads, Fast intake, wet sump and smaller cam, 244 259 @ .050. makes about 600/570 on a chassis dyno while being run up to 6800rpm. With the gearing and torque available it doesn't seem to make a difference when you shift as long as its above 6000rpm.
the way your engine builds power should be great for autocrossing. Always impressed with what comes out of the shop!
Matt
Old 07-16-2014, 10:27 AM
71RS/SS396's Avatar
Matt
Matt, you need the Ozmo intake for your engine , that Fast intake is choking it, I saw a 50 hp increase with the Ozmo. The 102 mm tb is too small for the cubes you have.
