Old 06-30-2014, 05:20 PM
71RS/SS396's Avatar
Default New Bullet Pics
Pics of the new bullet going in my rig
Oil tank to fit between the firewall and inner fender
Old 06-30-2014, 05:24 PM
glassman's Avatar
glassman glassman is offline
Makes me kinda weepy eyed....
Good luck with the install and your relationship with your tire distributor....
Mike
Old 06-30-2014, 05:35 PM
71RS/SS396's Avatar
This one may actually be easier on the tires since the torque down low is a little less than what I currently have but the top end hp is significantly higher.
Old 06-30-2014, 07:32 PM
Jr's Avatar
Jr Jr is offline
Which rig is this going into?
Beautiful intake!
Old 06-30-2014, 07:42 PM
71RS/SS396's Avatar
Beautiful intake!
My 70 Camaro
Old 06-30-2014, 10:22 PM
gerno's Avatar
gerno gerno is offline
Can you give out some of the specs for the new beast?
Old 07-01-2014, 03:21 AM
71RS/SS396's Avatar
Hp is well north of 700 hp @ 7,800
It's 450 ci
RHS block 4.165 bore X 4.125 stroke
Ported LS7 heads
Dailey 5 stage dry sump
Cam specs:
Hydraulic Roller
Intake Exhaust
Lift .675 .675
Adv. dur. .302 .324
Dur.@ .50 251 265
Lobe sep. 112
Old 07-01-2014, 06:19 AM
ccracin's Avatar
ccracin ccracin is offline
Really nice Tim. That should be entertaining!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 07-03-2014, 07:43 AM
71RS/SS396's Avatar
I hope it will be, I'm going to experiment with the lsa of the cam in an attempt to bring the peak power down in the rpm range to increase the life of the engine.
Old 07-03-2014, 08:43 AM
wiedemab's Avatar
wiedemab wiedemab is offline
Yikes -- that sounds like it's going to be wicked....
- - I have a Nova that you could store the old engine in!
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
