Old 12-04-2014, 06:51 PM
DBasher's Avatar
DBasher DBasher is offline
I've got nothing to say about the pan/rack issue but that induction and the cowl vents are pretty dang neat!
Good luck with it
Dan
Old 12-04-2014, 07:45 PM
manOwar manOwar is offline
Originally Posted by Che70velle View Post
Dry sump?
Originally Posted by Dr G View Post
Maybe not even a true dry sump but just a crank driven oil pump. I think Rob from No Limit did this on his original slant cab F100 pro touring truck so he could lower the engine further.
That looks promising, I'll look into it... a dry sump pan will get me 3" lower. Thank you!
The kicker here... I sold a Roush Yates dry sump engine that I was going to put into this car....
Old 12-04-2014, 07:46 PM
Good luck with it
Dan
Thank you!
Old 12-06-2014, 08:56 AM
408sbfmustang 408sbfmustang is offline
I did the same thing when I installed a heidt's mustang II in my 65. I ended up installing a Peterson wet/vac sump pump on the motor. Ended up cutting the front sump of the pan off and welding in a flat piece on metal.
http://www.petersonfluidsys.com/pump_wetvac.html
Old 12-06-2014, 03:31 PM
Dr G's Avatar
Dr G Dr G is offline
There's these guys too. Aviaid.
http://aviaid.com/products/pumps/sre...lade/form.html
Old 12-07-2014, 06:06 AM
Thanks for the replies, I'm gathering up the parts now.
