Old 12-03-2014, 11:05 AM
manOwar manOwar is offline
Default IFS - Front Steer vs. Rear Steer
Hi all,
I'm in the process of building my first PT style car. It's a '66 Fastback that had an R&C kit already installed in it. The issue with this IFS and the windsor engine is the front sump. It's design doesn't allow the engine to be moved back without raising it. However, if the rack can be moved to the rear of the cross member, the engine could easly be moved back the lowered.
My question is, what kind of issues am I going to run into if I do this?
The current set up has:
225/45/18
8" wheel with 6.25 BS
14" brakes
Tire CL of 52.72
Wilwood Spindle
-1.5" Scrub
As you can see from the mock up, the engine is moved back about 4-5". It's also sitting 4-5" higher in the front and at a 5* angle.
Any input or advise would be appreciated.
Old 12-03-2014, 11:34 AM
Vince@Meanstreets's Avatar
My advice,
get a new pan in favor for a rear sump.
Your gonna do a lot of modifications that may not work right for a $700 oil pan.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-03-2014, 11:36 AM
Ron Sutton's Avatar
My advice,
Agreed x2
Ron Sutton Race Technology
Old 12-03-2014, 03:22 PM
My advice,
It is a rear sump... the front sump is required for the oil pump...
Old 12-03-2014, 04:34 PM
Blake Foster's Avatar
PUT an LS in it......................
you can't use the front steer rack as a rear steer, unless of course you switch it to right had drive..........
Blake Foster
www.speedtechperformance.com
Old 12-03-2014, 05:26 PM
LOL!! It would look a little funny sitting backwards on the front bumper trying to steer it!!
Old 12-03-2014, 07:41 PM
You could lower the rack, how much room do you think you need? Might help your bump steer. Combination of a lowered rack and modified pan perhaps?
edit...looks like its sitting on the lower arm mount though
Dealer for
NEVER FORGET -11
Old 12-04-2014, 11:09 AM
I need about 4". I can't lower the rack and the pan can't be modified due to the oil pump.
I spoke to one of the manufacturers that builds these this morning and it's a no go on changing it to rear steer....
Old 12-04-2014, 04:06 PM
Che70velle's Avatar
Dry sump?
Thanks Dad!!
Old 12-04-2014, 07:46 PM
Dr G's Avatar
Dr G Dr G is offline
Originally Posted by Che70velle View Post
Dry sump?
Maybe not even a true dry sump but just a crank driven oil pump. I think Rob from No Limit did this on his original slant cab F100 pro touring truck so he could lower the engine further.
