Old 01-28-2015, 08:07 AM
dontlifttoshift's Avatar
Originally Posted by rchaskin View Post
If I remember correctly, someone said that if you pull out the hose bungs in the waterpump, the holes that are left are the tap drill sizes for 1/2 NPT and 3/4 NPT. Then they installed allen head plugs in the holes. It looked really clean. You will have to search to find out for sure.
3/8" and 1/2" NPT. The holes are the right size, just run a tap through.
[IMG][/IMG]
Donny
Old 01-28-2015, 10:23 AM
rchaskin's Avatar
rchaskin rchaskin is offline
Ahhh...Thanks for the clarification!!!
Randy
1971 Nova
https://www.youtube.com/user/rchaskin/videos
Old 01-28-2015, 08:02 PM
jwcarguy jwcarguy is offline
Banned
I like using the Gates Power Grip clamps
http://www.gates.com/products/automo...grip-sb-clamps
I believe they make them for Afco as mentioned earlier
Jeff
Old 01-28-2015, 09:05 PM
I was just watching You Tube tonight, Hot Rod Garage and they said never block the heater out lets it was big trouble, you should loop it if your not going to use it. I don't know I've never had an LS but figured I'd mention it. Anybody know for sure either way?
https://www.youtube.com/watch?
v=4UGlYx_Cjjo&list=PLGvTvFzdMg_PbG7_1TPiABMmItllqq Fbb
Old 01-29-2015, 06:05 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
What is the logic behind that statement?
Presently every aftermarket AC system has a solenoid valve that closes of the water to the heater core when heater is turned off.
Old 01-29-2015, 07:24 AM
jlwdvm jlwdvm is offline
I think some believe that if the heater hose outlets are blocked off it won't allow all the air to be purged out of the cooling system when filling for thte first time. Thanks for the hose part numbers!
