Old 01-26-2015, 06:34 PM
jlwdvm jlwdvm is offline
Default LS3 radiator hose clamps and heater hose bypass?
Just wondering what you are using for upper and lower radiator hose clamps....something nicer than a regular worm-drive clamp! Also, I won't be running a heater. does anyone make a curved by-pass hose that is a different size on each end for the LS3?
Old 01-26-2015, 06:46 PM
IMPALA MAN IMPALA MAN is offline
Default Hose clamps
http://www.afcodynapro.com/store?sea...xt=Hose+clamps
Old 01-26-2015, 07:10 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Originally Posted by IMPALA MAN View Post
X2 That's all I use and have never had an issue with leakins
Old 01-26-2015, 07:13 PM
....I meant "?" not "!"....oops. How do you choose the clamp size? Let's say that the installed hose has an outside diameter of 2". Do you choose a clamp that is 2-1.75 or 2.25-2?
Old 01-26-2015, 07:24 PM
Musclerodz's Avatar
The smallest one you can get to slide over the hose with it installed.
Mike Redpath
Musclerodz & Customz
facebook page
Old 01-27-2015, 07:31 PM
mikeextrafast's Avatar
mikeextrafast mikeextrafast is offline
I used the factory style clamps that came on my LS they look better than worm clams
Old 01-28-2015, 06:00 AM
rchaskin's Avatar
rchaskin rchaskin is offline
......Also, I won't be running a heater. does anyone make a curved by-pass hose......
If I remember correctly, someone said that if you pull out the hose bungs in the waterpump, the holes that are left are the tap drill sizes for 1/2 NPT and 3/4 NPT. Then they installed allen head plugs in the holes. It looked really clean. You will have to search to find out for sure.
Randy
1971 Nova
https://www.youtube.com/user/rchaskin/videos
Old 01-28-2015, 06:04 AM
I thought that if the outlets were simply capped off there would be an air pocket trapped behind them?
Old 01-28-2015, 07:48 AM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
I did this for NPT to AN adapters for my heater hoses, could just as easily put a pipe plug in there. No drilling needed, just patience with a pipe thread tap.
Erik
69 Camaro
Old 01-28-2015, 08:13 AM
BBPanel BBPanel is offline
Dayco #87629 or Kelly-Springfield #S-4354. Not sure what the cross reference numbers are for Gates etc.
