Old 10-24-2015, 05:51 AM
Z06vette's Avatar
Z06vette Z06vette is offline
Here's a link to the ebay auction for the spring if anyone is interested
http://www.ebay.com/itm/Soft-Reverse...204094?vxp=mtr
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 10-24-2015, 06:18 AM
SSLance's Avatar
SSLance SSLance is offline
I used one of these on my install...stand alone solution...
http://cart.grcperformance.com/oscom...products_id=69
Lance
Old 10-24-2015, 08:43 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
You can do the same thing by adding a pin and wire to the harness.
But this is easy for guys that don't have ECMs
Old 10-26-2015, 06:32 AM
rickpaw rickpaw is offline
How do you do that? Is reprogramming required for the ECM. I have an older red/blue ECM running a 5.3, and I'm going to convert to a 6 speed.
Tu Ho
Old 10-26-2015, 06:54 AM
Vega$69's Avatar
Look up the pin outs for your ECM and add a wire. The wire you add will provided ground based on VSS. Run 12v ignition to the solenoid and the wire from the ECM and it will activate the solenoid under 2-3 mph.
Would not need any programming if your ECM has RLO.
Old 10-26-2015, 08:51 AM
dontlifttoshift's Avatar
I've posted this before, why is there not a shifter with a manual lockout. Pull up on a ring or push down on the knob to get reverse.....soup. That should exist.
Shifter company could use the opportunity to design a shifter that doesn't leak, also.
Donny
