Old 10-22-2015, 08:50 PM
Swain's Avatar
Swain Swain is offline
Default T56 Reverse question
So my T56 isn't going into reverse it seems like it doesn't engage enough. Does the reverse solenoid need to be wired up?
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 10-22-2015, 10:26 PM
Sieg's Avatar
Sieg Sieg is offline
YES!
To the brake switch.
Old 10-22-2015, 10:42 PM
Swain's Avatar
YES!
Thank you sir
Jason Swain
Old 10-23-2015, 05:25 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
YES!
You don't need the RLO wired for it to go into reverse. It just harder to push it over without it.
If you wire it to the brake switch every time you touch the brakes the solenoid will activate. It works but IMO not a good solution.
You can pull a wire from the ECM and it will work off VSS or you can add a switch as I did
I have mine wired to a button switch in the shift ball.
http://www.camaros.net/forums/showthread.php?t=355737
Old 10-23-2015, 08:04 AM
Z06vette's Avatar
Z06vette Z06vette is offline
I changed the spring to a lighter one, goes in with minimal effort now. Still enough resistance to avoid engaging reverse unintentionally.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 10-23-2015, 08:27 AM
Sieg's Avatar
I like that option.
I wired mine per kit instructions.
Old 10-23-2015, 08:49 AM
Vega$69's Avatar
I like that option.
I agree. Pretty hard to hit reverse unless you're power shifting into 5th
Old 10-23-2015, 06:36 PM
im4u2nvss im4u2nvss is offline
I changed the spring to a lighter one.
Any further info on this spring? (part # exc.)
Old 10-23-2015, 08:17 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
I would not install a weak reverse lockout spring, I would wire up the solenoid as it was intended. I also have my reverse solenoid wired to a line lock button on the shift knob.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 10-23-2015, 08:38 PM
Sieg's Avatar
With a close ratio box that could be and issue on a fast road course.
