Old 07-20-2017, 07:01 PM
I got in touch with GM today they told me to get a Metri pack 150 4 pin connector and put the wire from my harness in the B slot and plug it in . He said that's all it needs. When I told him the story about the Alt and plug difference he put me on hold and when he came back that was his reply. He sent me an e mail with a schematic and picture of the connector and told me to ignore the schematic.
I'll try to post it tomorrow.
Old 07-21-2017, 10:59 AM
andrewb70's Avatar
Originally Posted by dhutton View Post
LSA Connect and cruise instructions state that the use of the alternator control is optional and then they toss in this warning:
NOTE: If you are using the Chevrolet Performance or production LSA generator DO NOT plug in the generator control wire into the generator. This will result in the generator defaulting to only an 8 volt output above 3000 RPM.
I think you will be better off using the alternator you have and wiring in the appropriate plug. Holley sells one if you are unsure what plug to get.
Instructions here:
https://static.summitracing.com/glob...l-19257456.pdf
Don
Don,
I am just trying to wrap my head around this...and maybe follow GM logic...So the harness has a 2 pin connector, but are you saying that the ECU is not set up for PWM alternator control?
Why would they install the 2 pin connector?
Andrew
Old 07-21-2017, 11:04 AM
The two pin connector only has one terminal in it which they said, put it in the B slot and plug it in were his exact words.
Old 07-21-2017, 11:07 AM
andrewb70's Avatar
So it sounds like GM messed up the connector and really should have installed the older style 4 pin connector. My GMPP kit that I got back in 2008 has a 4 pin connector but only one wire is in it (B slot...L terminal).
You may be able to remove the terminal from the 2 pin connector and slide it into the 4 pin connector that you get from Holley. Those Metripack 150 connectors (assuming the 2 pin is also a MP 150) should use the same terminals.
Andrew
Old 07-21-2017, 11:33 AM
That's what I was going to do, but it's about 2' too long so I'll shorten it to clean it up. I guess they make it that long in case your using the lower alternator location. Mine is on top.
Here's the number for GM power train and Performance 866 453412
Old 07-21-2017, 02:09 PM
andrewb70's Avatar
Wayne,
I am pretty sure that I have the terminals for the 4 pin plug. I know I used some to add a wire to that connector on the S terminal. If you want, I can send you a few of the terminals...provided you have the right crimping tool.
Andrew
Old 07-21-2017, 05:13 PM
Originally Posted by andrewb70 View Post
Wayne,
Andrew
Thanks Andrew I got the terminals I'll be doing that in the next couple of days. Thank you!
