Old 01-15-2007, 08:51 PM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
Originally Posted by Mizfit
You should give us a call we are having a special on our Turkey LS7 427 packages righ now $400 off pacakge price...www.mizfitmotorsports.com. But more importantly we have a similar setup going into our 69 camaro. Really great setup for us pro-touring guys. Good Luck with your project.
Oh so its "TurnKey"....Just went to the site to check it out.
I tought it was a late Christmas special...
Lead. (Hehe)
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
Old 01-15-2007, 09:36 PM
Mizfit's Avatar
Mizfit Mizfit is offline
My Bad yes TurnKey
Old 01-20-2007, 05:08 PM
R67Chevelle R67Chevelle is offline
My Bad yes TurnKey
Hey since you have LS based packages, since I was looking at this direction what about a say 402 with blower cam and AFR heads, ken bell or whimple supercharger say about 750hp and about 700ft.lbs. turn key set up.
Can u guys do something like this?
Blessings
Old 01-20-2007, 05:30 PM
Mizfit's Avatar
Absolutely...If you want to do a Kenne Bell setup or any blower for that matter i would go for just a patriot stage 3 head(Cheap and flows very well). Even though the AFR's have a thicker deck which in turn = stronger for FI, I would spend the extra money in other area's. If i were you i would do a setup like ours, but maybe 402 if you wanted:
LS2 Block
Patriot Stage 3's - Complete
Callies Rods
Eagle crank
Wiesco Pistons -32 dished
LS6 oil pump
LS2 timing chain
Kenne Bell Supercharger (10-18 psi) // Whipple is a lot taller and may have issues with clearance even with a cowl hood.
Custom Blower Cam
If you want I can pm or email you a price on a Turnkey Setup or if you like please feel free to give us a call anytime I would be more then happy to go over your setup more in detail with you, so I can find out more of your goals for the car.
We do get good discounts from both Kenne Bell and Whipple so we are good in those areas.
Taylor
Mizfit MotorSport
913-558-1100
Old 01-20-2007, 07:30 PM
LS2 Block
Callies Rods
Eagle crank
LS6 oil pump
LS2 timing chain
Custom Blower Cam
Taylor
Mizfit MotorSport
913-558-1100
This sounds great... I sent u a PM now from LS7 NA to blown LS sounds like the final plan.... Big HP and fat Torque... Looking forward to it... Glad for ur posts and keeping it in the family...
Blessings,
Old 01-23-2007, 10:19 PM
pist0lpete pist0lpete is offline
Another option could be an L92 setup with an L76 intake. Heck you could throw on an ITB intake even and that would be way different and can you say throttle response? Texas Speed has the L92 418 cubic inch strokers for under $5k. The L92 heads are super cheap and flow extemely well for an as cast head. Take into account that this is a built motor with forged pistons rods and crank and its a much better deal than the hyper piston LS7 crate motor. Should make 500 rwhp without even breathing very hard and could handle a 200 shot of nitrous no problem or forced induction if you so desire.
Old 01-24-2007, 09:31 AM
Mizfit's Avatar
L92 stuff is great we also sell L92 short/long blocks. We also are the first company to build a Sheet Metal intake manifold for them. Affordable one at that.
Taylor Day
[email protected]
Old 01-24-2007, 10:38 AM
I believe I have seen your guys' intake and it is indeed a nice piece. Its paying upwards for $4000 for a sheetmetal intake that I cannot understand especially when that is ITB price territory. I didn't state it before but my plug of Texas Speed was merely because their price was easily accessible and I have dealt with them personally with great results. I did not mean to suggest you guys don't also build great products as I am sure you do. I wish I could do an LS7 or L92 in my chevelle but a forged 347 is gonna have to do for now. However, back on topic, what do you guys do for pistons in your L92 headed motors? From what I have gathered there aren't really any off the shelf pistons that have the correct valve reliefs.
Old 01-24-2007, 10:47 AM
Mizfit's Avatar
That is correct L92 pistons indeed are still custom. I believe Diamond is the only company that has correct valve reliefs out right now. I have contacted wiseco about getting on the ball with some. Yes our intake retails for around $2000 for the Sheet Metal with Fuel Rails and Hardware. We are running a sale right now here on Lateral-g.net for $1800. I didn't think you were pluging Texas Speed I just figured I should let people know we also build them since it is not on our website as of now.
Taylor
Mizfit
Taylor Day
[email protected]
Old 01-24-2007, 03:56 PM
Leadfoot1's Avatar
Hey Taylor,
I'd like to see that Fabbed intake!
Got pics?
Lead.
LEADFOOT1
