Old 01-09-2007, 11:44 AM
R67Chevelle R67Chevelle is offline
Default LS7 in a 67 chevelle
Well it looks like I am going to go for different. I am going to go LS7 with Katech cam and programing. Will yield about 630hp and 590 Ft lbs. Sould run well...
The all Alunimum engine should reduce weight greatly and the different factor is there. I can't decide if I was T56 - TKO 600 or 200r4 and going out back with 3.73. Anyways heres where I need some help.
With the dry sump and pan clearance will this fit without modification of my frame? I know you can get oil pans for the wet sump LS based engines with the necessary clearance adjustments. Will the LS7 need modification or is there a company that has products for this procedure?
Any suggestions would be appreciated. Going to start on thisend of April and trying to gather parts list together to plan for this whole build...
Blessings
Old 01-09-2007, 01:06 PM
Sounds like a dream project for me !! Keep us posted how the engine build went with Katech and if you can please dyno the engine with all accesorys so the power could be really know for sure. Oh and dont forget the pics!!!!
63 Z06
Old 01-09-2007, 04:55 PM
JUSTANOVA JUSTANOVA is offline
I beleive ATS has everything your going to need, I have only heard good things about their parts/people.
<-------------check em' out
Project EARTHQUAKE:
72 Nova SS, Plans have changed a little:artmorrison front subframe, and rear 3 link, pretty much stock ls1 and six speed with a single turbo for around 550hp. with a few other things mixed in.
current cruiser: "The green machine"
'70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct
and why do we modify everything...."BECAUSE STOCK SUCKS"
Old 01-09-2007, 08:50 PM
jeff hanson's Avatar
jeff hanson jeff hanson is offline
The stock pan should work. ATS makes motor mounts that let you mount the original style mount to the LS7. Chevelles have front steering gear so there shouldn't be any interference with the pan. Not to say that you couldn't still switch it to a wet sump if you wanted to. sounds like another cool project. Keep us updated. I've had 2 67 Chevelles, definetely the best year IMO!
Old 01-10-2007, 03:07 AM
Alex396ss's Avatar
Alex396ss Alex396ss is offline
Hi!
Cool choice, I´ve been thinking of that engine too for my ´67.
Can you estimate the totalcost for everything?
Alex
- ´67 Chevelle SS396 - ProTouring project
- ´97 GMC Suburban - Family hauler
- ´07 BMW 335iAT M-sport - Daily driver
Old 01-10-2007, 07:25 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Lets see, you'll need the motor (I'd assume a crate motor which doesn't include any accessories like PS pump or alternator), an ECM, harness, (possibly the fly by wire accelerator, depending on whether you go OEM ECM or aftermarket), dry sump tank, adapter motor mounts, LS7 specific headers... Add that all up, and you'll get an idea on total cost.
My LS7 69 Camaro
Old 01-10-2007, 09:33 AM
Expensive is definately the word... I am now actually looking at going to Turn Key engine Supply's crate with cam and ECM upgrade.
http://www.turnkeyenginesupply.com/street_70630.htm
I can get all accessories. ECM, starter and fly wheel. I just hope the stock pan on the LS7 will clear. Different is definately more expensive. Thanks for the advise for ATS looks like they will work.
I really wanted to do a 700hp motor, but I hope 630hp will get me into the high 10's and just plain haul butt. Thanks for all the advice. If anyone else has somemore feedback or suggestions, please advise.... Thanks Guys
Blessings
Old 01-10-2007, 04:54 PM
Blessings
I just noticed you are in henderson, you aren't too far from the ats boys, they are in vegas.
Project EARTHQUAKE:
Old 01-10-2007, 05:27 PM
Hi!
Alex
I speak from experience...$$$$$$$$$$$$$$$$$ and $$$$$$$$$$$$$ and then $$$$$$$$$$$$$ oh yeah, did I mention $$$$$$$$$$$$$$$$ Have fun.
Old 01-15-2007, 02:44 PM
Mizfit's Avatar
Mizfit Mizfit is offline
You should give us a call we are having a special on our Turkey LS7 427 packages righ now $400 off pacakge price...www.mizfitmotorsports.com. But more importantly we have a similar setup going into our 69 camaro. Really great setup for us pro-touring guys. Good Luck with your project.
