Old 04-16-2007, 11:04 PM
Steve1968LS2's Avatar
Originally Posted by camcojb
well, both those items aren't bolt-ins, they require machine work. So you saved yourself some money and time!
I know, but if I had known I was going to tear down the engine I would have done it.
No biggie.. It's only time and money.. right? Ok, now I need another beer..
Old 04-16-2007, 11:26 PM
rockdogz's Avatar
rockdogz rockdogz is offline
Oh man that's rough... will make it that much sweeter when she's on the road!!
-Tom
camarorestoration.com
Old 04-17-2007, 04:29 AM
ProTouring442's Avatar
Just like in the build, it's always the little crap that gets you.
Does remind me of a dumb mistake I made years ago, kind of off topic, but I thought it might make you laugh.
Ever shim an oil pump with a welch plug? Know what happens when you do? Oil pressure is fine at idle, but as soon as you give it some gas, the bypass opens, lets the oil in, but it won't bleed out and locks the bypass closed. Did you know you can actually blow an oil filter right off of a 409 with this little trick? 'Bout peed my pants when it exploded the filter off of it's mount. Took me a few to figure out what I had done wrong!
Shiny Side Up!
Bill
'72 442 "Inamorata"
'89 ASC/McLaren
www.FQuick.com/ProTouring442
Old 04-17-2007, 06:15 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
A treatment problem with a Comp cam? Look around over at Team Chevelle, doesn't appear to be that uncommon.
Old 04-17-2007, 06:36 AM
Payton King's Avatar
Default Steve, what can I say..
Keep you head up little buck-a-roo? I don't think that would help. That really sucks! Now I am all freaked out about starting mine. Running a comp grind as well.
I will be thinking about you and having a beer...just on the other coast
When things settle down give me a buzz.
Old 04-17-2007, 06:53 AM
superslow's Avatar
superslow superslow is offline
I was going to ask if you used a double roller timing chain on your engine. Reason I ask is because some of the sets have oil pump shims with them. Similar to what ProTouring442 had mentioned the driverside shim can be flipped upside down and still bolt on. It will cut off 2/3's of the oil passage to the upper engine. Something to look into if you did have shims. Dont ask how I know.
Darrell Cook
67 SS/RS L35 Camaro - clone, fake, tribute or whatever you wanna call it; its not original.
68 SS L78 Camaro - all original unrestored ordered and purchased new by my father now mine.
68 302 Z - awaiting restoration
Old 04-17-2007, 07:16 AM
68protouring454's Avatar
wasn't this motor dynoed, why was the low oil pressure not caught then?? would of eliminated all of this and is exactly what dyno testing is for
killer car, killer motor goodluck
Old 04-17-2007, 07:19 AM
Now Now.. it's only a theory. Let's not bandwagon. They are next day airing the new one to me.
Old 04-17-2007, 07:22 AM
Oil pressure was fine on the dyno. It wasn't "endurance tested" for a long period. It was ran in then tested in stock form. Then tested with the heads and the last 10 pulls were made with the new cam.
Also, there's no evidence the low oil pressue is related to the cam issue. I feel the low oil pressue is a problem with the pick-up tube (crack or such). Will know for sure today.
Like I said, just part of the "car building experience".. what can ya do?
Old 04-17-2007, 08:07 AM
TonyL's Avatar
TonyL TonyL is offline
well that sucks.. Good luck Steve.
