Old 01-05-2014, 11:45 PM
cluxford cluxford is offline
can you get in the back of the disc and grind / cut the end of the stud away
68 Camaro 632 BBC 800+ HP Project (600Kw)
61 Buick Lesabre Bubbletop (daily driver)......miles of smiles
Old 01-06-2014, 06:57 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Or remove the axle and drill out the stud from the back.
Old 01-06-2014, 09:05 AM
Che70velle's Avatar
Again, I'd drill them from the front. You only have to go the depth of the nuts, and your golden. Use a high quality bit. Unless these are ARP studs, this should go quickly.
Thanks Dad!!
Old 01-09-2014, 09:54 AM
Viperlover's Avatar
Viperlover Viperlover is offline
I've had to drill out a stud before with closed ended lugs. Had to dimple the lug to get it to center and also had to use cutting fluid and not go too fast. I believe if you go too fast you will harden the stud/dull the drill bit. The cutting fluid was absolutely necessary in my case.
Old 01-09-2014, 03:01 PM
OBeer-WAN-Kenobi's Avatar
Originally Posted by mitch_04 View Post
I had a similar problem recently. I took a big bolt, welded the front of it onto the back of the lugnut, then put my socket on the bolt. The heat from welding also helps removal.
This ^
Or use another nut and plug weld it to the lug nut. If you don't have a welder and the car can still move, put the other nuts back on and drive it to a shop. They should be able to weld another nut on or get them off for a few bucks.
ETA: Whoops, I somehow missed a page. It looks like they are through-nuts, not acorns; if so, looking at your pictures and seeing how they are recessed in drilling them out seems like the best option. Just use a smaller pilot drill and then come back with another one that's about the same size as the diameter of the stud.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 01-09-2014, 03:07 PM
spacepirate spacepirate is offline
Thanks for the advice guys. I think you're right about drilling out the studs.
