Old 01-16-2014, 06:45 PM
69greyghost 69greyghost is offline
Default Just had my ls swap and had a few questions.
Hey guys, I just recently had my LS swap completed and I had a few questions. So the set up is a 69 camaro with an ls1 t56 set up. The motor has 241 heads and a mild cam. The t56 is a stock t56 with a ripper b&m shifter. The reason for my question is I had my ls installed and have some questions about tuning, and the difference between a 4 speed muncie clutch, and a t56 clutch? For one my car runs kinda weird and I was curious if the lack of tune was responsible for this issue. Next the clutch feels rather odd, I have the luk high performance clutch kit. I heard really good things about this clutch so I dont think thats it. It is difficult to get into first from neutral, I stall out alot. This may also be due to my lack of tune but I felt I should ask the experts for their thoughts. When I had my muncie 350 combo I struggled some with shifting also, maybe I need to get used to driving a v8 stick set up. Let me know what you guys think.
Old 01-17-2014, 09:42 PM
gnx7's Avatar
gnx7 gnx7 is offline
If it has a cam and headers, and the computer isn't for a manual transmission car... you definitely need a tune.
What size cam?
I assume you kept the MAF sensor?
Do you know what temp the efan turns on/off?
How do you know it is even has a safe tune?
A new clutch will require a few hundred miles of in town driving to break in a little.... 1000 miles it should be fully broken in.
Old 01-18-2014, 01:55 PM
It does have Dynotech headers and a cam, the cam specs are 230/236 on a 112 lsa. I think the computer maybe for an automatic but I am not sure. It has a different maf sensor, it has the 5 pin maf sensor. The fans turn on, I am not sure if it is safe to tune but I assume so. What are some reasons it would not be safe to tune? I guess my question with the clutch is will the tune make coming out of first easier where i dont have to hit the gas so hard? Like I said the 4 speed clutch was difficult but easier than the t56 clutch, I never stalled that much with that one.
Old 01-18-2014, 07:59 PM
Z06vette's Avatar
Z06vette Z06vette is offline
Def need a tune with that cam. & yes i can see it being a bitch on take off if tune is off. I wouldn't run it hard in case its running lean in upper rpm range. Driveability is toughest part to tune. That's a fairly decent sized cam for stock ls1. Even with tune you'll need to give it little bit of throttle when letting clutch out from dead stop. Spend the money on a good tuner it will be worth it and be right the first time.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 01-19-2014, 02:24 PM
Ok, that makes sense. I was told the cam was not really all that big. After hearing it in the car it does sound rather radical even with no exhaust . I was gonna go straight to paint but I think I am gonna get exhaust, tune, then I can drive the car to wherever I have to instead of towing it.
Old 01-20-2014, 01:22 PM
67Rally's Avatar
67Rally 67Rally is offline
It sounds like you also need the clutch adjusted if you're having trouble going from neutral to first.
Definitely get it to a competent tuner, and don't beat in it till then.
Old 01-24-2014, 10:57 AM
Solid LT1 Solid LT1 is offline
230/236 on a 112 LSA? That's pretty big with lots of overlap. The MAF if your running one won't be to happy if it's anywhere close to the throttle body and the MAP sensor, it's not happy at all at idle Ill bet. A good tuner can work around most of this where do you live?
