Old 02-15-2016, 07:05 AM
jlwdvm jlwdvm is offline
http://www.americanautowire.com/PDFL...0IN%2010.0.pdf
This is a picture of what I have...the Power Plus 20 ignition plug. I view this diagram as looking at the wire side of the plug, so when it is plugged into the ignition switch the purple and pink wires are all the way to the left. During testing I removed all but the red wire and tested for voltage at various terminals on the plug with the key in various positions.
Old 02-15-2016, 07:19 AM
dhutton dhutton is offline
According to the photo here the AAW diagram is viewed from the connection side, not the wire side. At least that is my interpretation.
http://www.justanswer.com/chevy/7e2c...html#re.v/510/
Don
Old 02-15-2016, 07:26 AM
Don
I think this is saying the same thing:
http://webspace.webring.com/people/d...y_jeep/is2.jpg
Don
Old 02-15-2016, 07:34 AM
I'll call AAW today and see what they say. Thanks for the help!
Old 02-15-2016, 08:34 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Using the multi meter test the switch for continuity is all positions. Off, run, start
Either the switch is bad or the rod from the key to the switch is wrong or not installed correctly. I also think there a differences in them for tilt and non tilt columns
Check this out. It may be your problem
http://www.camaros.net/forums/showthread.php?t=171005
Old 02-15-2016, 08:44 AM
71RS/SS396's Avatar
I purposely posted this pic upside down since this is how the switch pins will look when mounted on the column and viewed from the passenger side of the column. The white connector shell only has 4 wires, if you place the wires in the shell as marked in the pic you should be good to go. AAW shows a non-tilt switch in their diagrams so the wires are upside down and 180* out from a tilt column switch.
Old 02-15-2016, 09:17 AM
BINGO! I'll check when I get home today, but I can already tell you that I currently have the pink and purple wires switched.
Old 02-15-2016, 09:31 AM
Vega$69's Avatar
if you have the pink and purple reversed the starter will spin with key in run position.
Old 02-15-2016, 07:06 PM
I flipped the purple and pink wires from their original positions...now the pink is on top and purple is on the bottom. Everything now works as it should! I primed the motor again last night and after checking all my wiring over and removing my primer I spun the motor over to check oil pressure. I was able to get oil pressure up to 40psi after a fair amount of cranking. Motor fire up is nearly upon us!
Old 02-15-2016, 08:12 PM
JKnight JKnight is offline
Great post Tim, that was clutch.
