Old 10-28-2011, 08:21 PM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by LarryC5 View Post
Sieg/Matt
How in the end did T56 trans workout for you two? I had to stop at mock-up due to a heavy work schedule.
Curious how the transmissions are performing on the road. You both were quite ahead of me....
Larry
Larry,
I couldn't be happier. The close ratio gear spacings are perfect for me. The throws on the Blackjack shifter are short and precise.
Old 10-29-2011, 04:48 AM
usa-69z usa-69z is offline
instead of starting another 'shfter location' thread i thought id post here and see if any of you guys can help an aussie out !
i have a tremecT56 6 speed from an Aussie 2002 GM Commodore SS..I want to fit this in my 69 sbc camaro. Now from most pics i see of these 'camaro kits' the shifter is much further foward than what my box seems to use? I have measured from end of box to stick and its roughly 28inches. What do i need to purchase to get this is the 'ballpark' position..
I do not use a console and my car was originally an auto car.
thanx , Gav
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 10-30-2011, 09:22 PM
68LS1's Avatar
68LS1 68LS1 is offline
I wonder if you can swap tail extension from T56. F body one will get shifter further forward, or better yet will Keisler or Hurst Driveline aftermarket one fit, do they sell seperately?
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
Old 10-31-2011, 12:34 AM
Rodger , this box is a T56 .. whats an F body one?
the problem that i see on all the aftermarket shifters for these boxes is the plate which holds the shifter on is of smaller size ?
measures - 5 5/8 long and 2 7/8 wide.
im hoping a keisler/hurst/powertrain rep may chime in ???
ive sent emails to all with no replies
Old 10-31-2011, 04:13 AM
68LS1's Avatar
Gav, FBody is the Camaro or Firebird version, this is what I have in mine.
I think these may be same as the T56 in our VT Series 11 to VY Commodores
Mal Wood is probably best to confirm.
Roger
Old 10-31-2011, 11:23 AM
Rybar's Avatar
Rybar Rybar is offline
Gav, looks like you have a GTO style T56. You can probably use any of the F-body shifters like Hurst, B&M or Mcleod.
http://www.classicchevy5speed.com/Mc...ndustries.aspx
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 10-31-2011, 01:18 PM
Sieg's Avatar
Gav,
The 93-02 Hurst Billet Plus Camaro shifter may work:
http://www.hurst-shifters.com/hurst-...LUS-SHIFTER_4#
Looks like it may position the shifter forward 2.5-3" is that enough?
Old 10-31-2011, 03:02 PM
thanx guys ,, i feel like im getting somewhere now..
question , do you think a 'billet plus' hurst shifter would be in an ok position ? with a straight stick.
i dont run a console and have no holes cut in floor (yet) .
Gav
Old 10-31-2011, 04:07 PM
Sieg's Avatar
Someone is fabricating offset handle brackets like the one in my picture for Hurst and other vendors. Between an adapter and possibly a modded handle you should be able find a sweet spot.
If LarryC5 has his trans close by maybe he can throw a tape on it and give you the bellhousing to shifter position length on the T56 Magnum with Blackjack shifter which locates in the original factory position. Which with a replica Hurst shift handle is very comfortable. I have had no desire to relocate the handle position. It fits like a glove so to speak, its' close to the wheel and I don't feel like I'm reaching for it. For reference: I'm 5'-11' with 31.5" inseam, 72.5" wingspan.
Old 10-31-2011, 04:49 PM
Rybar's Avatar
Gav
This is exactly what I run and the shifter location is perfect IMO.
1969 CAMARO RS
