Old 09-05-2012, 01:04 PM
edge04 edge04 is offline
can the hydroboost and MC be installed under the dash? Knowing I would neeed to possibly make a bracket what else might be an issue?
Old 09-06-2012, 05:17 PM
Hydratech®'s Avatar
Hydratech® Hydratech® is offline
Supporting Manufacturer
HydratechBraking.com
Not a problem - we set customers up with our universal models for use with the Kugel Komponents underdash pedal assemblies on a very regular basis.
Here is a link to our universal models:
http://www.hydratechbraking.com/Universal.html
These models are designed to bolt in place of the typical 7" and 8" dual diaphragm vacuum boosters (which means they can substitute the vacuum boosters typically used in the Kugel Komponents pedal assemblies as a direct plug n play upscale option).
Here is a link to the Kugel Komponents underdash conversion pedal assemblies:
http://www.kugelkomponents.com/zenca...a7ef19ebeaed6f
You will have to plumb PS lines and brake lines to the components under the dash to make it happen, so there is some further complexity to making this happen, though we have many customers that have successfully installed these systems under dash without concerns.
There IS a difference - Thank you for choosing Hydratech!
Paul M. Clark <-- the Ukrainian - Slava Ukraini !
Founder / Master Engineer
Hydratech Braking Systems ®
Old 09-06-2012, 05:49 PM
Awesome!! but you may have just sold me on a fire wall install with the pics in the other post lol
I'm building a twin turbo 1966 Nova. Plan was to keep engine bay as clean as possible. Let me sort through some of the other items needed in the bay and get back to you with an order. Thanks!!
Old 09-06-2012, 06:43 PM
Hydratech®'s Avatar
Here is an early Nova installation for visual reference as to installed layout:
http://www.pro-touring.com/showthrea...power-steering
Old 08-09-2013, 08:47 PM
OVRKILL's Avatar
OVRKILL OVRKILL is offline
The beast rolls....and stops hard enough to make your nose bleed. Apparently you can stop 800hp
Thanks again to the guys at Hydratech! Guys that completed the street tune said, "BRAKES ARE AWESOME!!! Only dropped the lap top twice before we figured it out!" Wicked combo guys, thanks again!
Photo shoot coming this weekend....in the interim
'01SS - RHS 460
Fikse / MWC / Kinsler / Mast
Enough torque to buckle pavement!
"Went right past silly and all the way to stupid..." - Shawn Miller
