Old 04-10-2012, 02:38 PM
OVRKILL's Avatar
OVRKILL OVRKILL is offline
Default Hydraboost or Elec Vacuum Pump?
Going to require a vacuum "assist" solution in trying to avoid sharing the MAP sensor vacuum source with the booster in my 4th gen fbody. Kinsler HIGHLY suggests in order to keep the MAP "quiet" I need to dedicate sourcing the intake vacuum and brakes/steering seperately. Because I'd rather not compromise either in terms of performance, does anyone have experience with either? I heard Elec Vac Pumps can be noisy and unreliable....thoughts? Sources for either?
TIA!
'01SS - RHS 460
Fikse / MWC / Kinsler / Mast
Enough torque to buckle pavement!
"Went right past silly and all the way to stupid..." - Shawn Miller
Old 04-10-2012, 03:09 PM
Ask anyone with a Grand National about what they think of electric vacuum brake pumps. My buddy replaced two and then gave up and drives his without one. He's going over to Hydra boost.
Old 04-10-2012, 03:24 PM
Ron in SoCal's Avatar
Personal opinion Shube....hydroboost done right will remind you to wear seat belts for facial protection. Not sure who the leader is for fourth gens, but Hydratech is a leader in old car retrofits:
Paul M. Clark
Hydratech Braking Systems
http://www.hydratechbraking.com/
Ron in SoCal
69 Camaro in progress
Old 04-10-2012, 05:32 PM
Apogee Apogee is offline
Hydroboost...if you've got a questionable vacuum situation, I'd just remove it from the equation.
Tobin
KORE3
www.kore3.com
Old 04-10-2012, 05:53 PM
OVRKILL's Avatar
Lol, had a couple myself...but never had to deal with it. Noted....
Tobin
KORE3
I was 70/30 in favor of the hydro simply because it makes the most sense. Thanks Tobin
Paul M. Clark
Haha...my man! Just talked to Jim over there today Appears they can have one in my paws in a couple weeks! Cuttin in CLOSE to PT though!!!
Oooh and there's a shiney option too!!
http://www.hydratechbraking.com/GM_4thgenF_Body.html
It doesnt make sense to put those big 'ol binders up front without them making your nose bleed when you gotta stop right?
'01SS - RHS 460
Old 04-10-2012, 08:55 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
There is no doubt that hydroboost will give you more than enough power to lock up the front wheels, but how do you want the pedal to feel? I've heard hydroboost setups have a "light" pedal feel. Maybe that is something someone else can elaborate on. Personally, I like good ol' fashioned manual brakes, when they're done right.
Really, you just have to figure out what is right for you based on you intended purpose for the car, etc.
Matt
Old 04-11-2012, 01:35 PM
RoadHammer RoadHammer is offline
I ordered my hydroboost unit from Jim @ Hydratech for my 3rd gen F-body (with show-prep) and It looks really good. Jim's a good guy to deal with as well.
Old 04-13-2012, 11:52 AM
OVRKILL's Avatar
^^^ Just ordered it this afternoon!!
Thanks again Jim! (I know you're reading this )
'01SS - RHS 460
Old 04-13-2012, 11:24 PM
gearheadgarage's Avatar
gearheadgarage gearheadgarage is offline
Regarding pedal feel, Hydroboost has a phenomenal feel.
You can actually feel the pedal "talk" to you- takes a little to get used to, we use 'em all the time and customers are elated!
Factoid: most all brake systems put about 800psi to the calipers/pads, Hydroboost systems give about 1200psi. That equates to 50% better braking pressure
Paul @ HydraTech is the man!
Old 04-27-2012, 01:04 PM
OVRKILL's Avatar
Bad ass set-up! Just got it this afternoon. Can not wait to get this in place......Thanks again to Jim and the Hydratech team!!
'01SS - RHS 460
