Old 08-12-2024, 03:29 PM
I really wish I remember who it was many moons ago made a power mirror set up for those mirrors
Old 08-12-2024, 11:01 PM
TechNova TechNova is offline
I use G-Body sport mirrors. They are remote operated from the factory. They have a cable on them stock. I make new mechanical parts for them to make them manual adjustable.
I have tried a few different ways of doing it. This is not easy. I knew someone would eventually ask the question so here are a few photos. To get it to fit in the housing is a lot of trial and error.
Thanks, I will play around and copy that, like trial and error. In the 80's I tied off the manual cable inside the door and it worked but I want to do a little better now.
Old 08-14-2024, 08:13 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
I might be remembering wrong, but wasn't there a C3 power version?
Scott from NJ
Old 08-14-2024, 08:16 AM
Curious why G body - are the bases better suited for 1st gens? Like a better angle, etc.
Scott from NJ
Old 08-14-2024, 08:28 AM
Stielow's Avatar
Stielow Stielow is offline
Default Hobbs Camaro (Old Drag Car)
https://www.ebay.com/itm/38719416483...mis&media=COPY
They bolt on with studs (more solid) and have a slightly longer neck.
Stielow Engineering
Old 08-16-2024, 08:34 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Mark, are these mirrors direct replacement for 68-69 camaro mirrors?
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 08-16-2024, 09:13 AM
Stielow's Avatar
Define direct replacement. It is not a direct replacement. Some assembly required.
Stielow Engineering
The Following User Says Thank You to Stielow For This Useful Post:
camcojb (08-23-2024)
  #448
Old 08-16-2024, 09:13 PM
72Z/28's Avatar
Thanks for the reply. I mean if the base of the G Body mirror and the stud spacing match with the 68 camaro mirror base, so there is no need to drill holes at different locations to fix the G Body mirror.
72 Camaro RS:SOLD
68 Camaro:
The Following User Says Thank You to 72Z/28 For This Useful Post:
  #449
Old 08-18-2024, 06:05 AM
Stielow's Avatar
Yes you need to drill two holes and sort out what to do with the remote mirror control on the drivers side.
Stielow Engineering
  #450
Old 08-23-2024, 04:52 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Originally Posted by dontlifttoshift View Post
Kwhizz will know for sure but that looks like Great Lakes Dragaway in Union Grove.
I'm a little sad the bonkers paint isn't on the car.
Yep..........Pic from the Grove!!!!!!!
The Following 2 Users Say Thank You to kwhizz For This Useful Post:
camcojb (08-23-2024), dontlifttoshift (08-23-2024)
