Old 09-27-2012, 06:38 PM
coolwelder62's Avatar
I would use Navel Jelly.
Old 10-12-2012, 06:07 PM
krptonite's Avatar
krptonite krptonite is offline
there is a spray that is designed just for this situation, it lasts up to 2 yrs, troy trepanier sells it but can be got from most speedshops, its called drycoat.
Old 10-13-2012, 09:20 AM
jh99 jh99 is offline
Originally Posted by bonecrrusher View Post
What are you going to use to knock that rust off the raw sheet metal?
I know it looks bad, but that rust is barely there. Scotch brute pads knock it right off. I could use some suggestions though bc I'm about to start soon.
Old 10-13-2012, 03:06 PM
NovaBlue71's Avatar
NovaBlue71 NovaBlue71 is offline
What are your plans for the outside of car? I would maybe think about just media blasting the car inside and out then spray car with some SPI epoxy primer. Joe
Joe VanNus
Old 10-14-2012, 03:26 PM
As for the outside: strip the paint, prime, and paint. Media blasting is definitely an option. I have read all about it, but I have no experience with it. What type of media is best for paint and surface rust?
Old 12-01-2012, 09:26 PM
A couple of more updates.
A view from the top. Steering column firewall mount.
Inside view of column mount
More of the A/C mounts. Easier to see with the dash back out
Detroit Speed windshield wiper motor is mounted. Took a little time but it fits now.
Dakota Digital outboard control module is mounted
Next is the American Autowire kit
I will have more in the next week or so
Old 12-01-2012, 09:38 PM
Lookin good. Man it must be humid there.
Old 12-01-2012, 10:27 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
I us something called Damprid from walmart in the garage to absorb moisture. It comes in what looks like a gallon ice cream pail. Just remove the lid and place around the car. My car has been in bare metal for about 2 yrs and looks good.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 12-02-2012, 09:35 AM
radrambler's Avatar
Default idea
I see your surface rust issue
When you get it removed.. im with Joe . media blasting would be great. then use Gibbs on the metal to keep it from happening if you cant paint it or dont want to right away.. Holohans hot rod shop ,Rad Rides and other pro builders use it AND SELL IT. If you contact Dan Holohan who is on this site he will sell it to you and explain it to you.. Dan is a great source of info.
Tom
Old 12-02-2012, 08:24 PM
Thanks everyone.
We have a lot of moisture down here. My plan is to media blast the car and prime everything when I'm finished with the metal work. Inside and out
Is anyone familiar with powder coating the entire shell? I have read a liitle about it.
