Old 10-18-2008, 06:59 PM
two68s's Avatar
two68s two68s is offline
Originally Posted by 10Seconds View Post
Ok, well despite the lack of responds here, I will continue to post my progress, as at least I am excited about it. Sheesh, next time I guess I should do a 69 camaro.
Ha! I know how you feel. Everyone on here drools over the Camaros even though each build is just like the one before it. So much has been done with a 67-69 Camaro that they all look the same to me. I've been following your build since day one. Keep up the good work!
I love the red. Please tell me you're gonna put the screaming chicken on the hood
-Jeremy
1968 Mustang Coupe: warmed up 289, C4
1968 Mustang Fastback: current project
Old 10-19-2008, 08:05 AM
californiacuda californiacuda is offline
Hey man, where did you get your skills? When I try anything close to what you've done it looks like s##t.
Old 10-20-2008, 05:44 AM
T_Raven's Avatar
T_Raven T_Raven is offline
i just found your thread. i dig the build man, keep updating. i'm a die hard firebird guy.
Old 11-14-2008, 06:46 AM
BanditDave BanditDave is offline
Hey Boss,
I am Magnacharging an LS1 in my '78 TA and have my eyes glued to your thread!!! Keep on posting! I will start my build thread this week too. I fired the motor a few weeks back...gettign the rear today.
I am very eager to see what the read looks like cause that was the original color choice for mine. I am now doing something a little different and using a Mazda color - Copper Red Mica. I tlooks RIDICULOUS!!!
Keep it coming brother, outstanding work!
Dave
Old 11-14-2008, 06:53 AM
silver63c10's Avatar
silver63c10 silver63c10 is offline
Awesome work, very very clean, don't know how I've missed this build. We considered using the CE frame rails like that, but decided against it after seeing how much work it was going to take. Love how you finished out the divider and tubs in the back, looks amazing.
Can't wait to see it all together, I'll definitely keep an eye on this thread.
Duston
Follow along on the insta
Old 03-09-2009, 06:46 PM
10Seconds's Avatar
10Seconds 10Seconds is offline
Well, not much has been happening on this the last few months, but finally, progress has been make.
Here is my new trans crossmember for the T56. The old one was just the factory one with the ends cut off and reworked a bit.
I am not 100% sure on the design, so I am open for comments, but I do think it will work. I will clean it up and change the bolts for final install. It leave me plenty of clearance for my 3.5 oval tube exhaust to run over it, rather than try and have some fancy bends in the crossmember to allow it to go under. So the benefit is actually better clearance and a straighter shot from the headers.
Thoughts?
Old 03-11-2009, 06:46 AM
10Seconds's Avatar
No one has any thoughts?
Old 03-11-2009, 08:50 AM
syborg tt's Avatar
The car is looking good.
One of the things that I would consider changing is the bolts. They hang down to low. Maybe weld a threaded sleeve into the subframe so all you have hanging down is the nut. You will gain considerable clearence which is going to be very important since I think you have this car pretty low to the ground.
I would just hate to see you snag a bolt on the ground and twist something.
As far as astetics go I personally like a tubular crossmember but that would require a tubing bender and plent more labor.
I almost forgot - maybe give Rodger a shout from Ironworks about the fuel cell.
Thoughts?
marty-mj
Old 03-11-2009, 09:16 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Does the transmission need to be at the level, or can it go up some? If you can move it up some, it will put your headers closer to the floor for more ground clearance. And I wouldn't want the crossmember hanging lower then the sub frame.
Old 03-11-2009, 04:15 PM
10Seconds's Avatar
No, trans is in the correct spot, correct angle, as is engine, but really, I think clearance will be ok, hard to tell from picture.
