Old 08-29-2014, 11:37 AM
Frankenstine's Avatar
Frankenstine Frankenstine is offline
Default Wow
OUTSTANDING work Mr Stielow .
Old 08-29-2014, 11:44 AM
andreb's Avatar
andreb andreb is offline
Like always, your builds are amazing. Your garage is awesome too. Thanks for sharing your knowledge with us.
Old 08-29-2014, 12:44 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
CLASSIC!! ...(and this gentlemen, is Mr. Stielow hard at work.)
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 08-29-2014, 02:29 PM
dontlifttoshift's Avatar
Mark, that's a lot of progress in a week.
Since you're pumping transmission fluid anyways, and reason to add or not add a filter inline?
Donny
Old 08-30-2014, 08:11 AM
Van B's Avatar
Van B Van B is offline
Is that brake ducting in the end of the frame rails, or? Awesome execution all around.
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 08-30-2014, 09:15 AM
Sieg's Avatar
Sieg Sieg is offline
Good eyes
Old 08-30-2014, 12:35 PM
Flash68's Avatar
Flash68 Flash68 is offline
Good eyes
and/or good memory.
Oh yes we are using the DSE Hydraformed rails for brake cooling ducts. I need to be more careful on the pictures I post....
Matt opened up the rail and capped off internally and added a curved piece to turn the air. 18 X 11 wheel no problems lock to lock.
With the Anvil lower front valance it is wide open for brake ducts. We squared off the end of the frame rail and removed all the bumper bracket holes. Then added front duct that pull of the opening in the lower valance.
Now that you guys figured that I can post the rest of the pictures when I find them.
With Carbon Ceramic Brakes you need a lot of air flow to cool the brakes. Especially when you are making 875 HP. They don't have much thermal mass so much the cooling needs to be by air flow.
Mark
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 08-30-2014, 11:59 PM
tom091074 tom091074 is offline
Mark, what's the plan for the brake cooling duct from the frame to the rotors?
Old 08-31-2014, 12:17 AM
LS7 Z/28 LS7 Z/28 is offline
Mark are you using -12 for both the feed and scavenge lines to the Peterson tank? Looking at their part numbers it's confusing because they have a -16 port for their LS7 pan adapter?
615-08-0502 -12X-12
615-08-0503 -16X-12 ???
Old 08-31-2014, 06:22 AM
Stielow's Avatar
Stielow Stielow is offline
I'm not sure yet. Still need to see how it rest of it packages.
Mark
