Old 06-28-2007, 04:27 PM
67ragtp 67ragtp is offline
Default Battery Tender- yes/no with EFI
Ok maybe its kind of a dumb question, should I be concerned about using a Battery Tender and having the battery connected to my EFI hardware(XFI) and MSD etc. The idea here is to trickle charge the battery and not have to disconnect the terminals right? Too much invested in electronics to blow, your thoughts?
Thanks Rich
Old 06-28-2007, 05:54 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Motorcycles use battery tenders all the time and most of them are EFI'd. I have a battery tender and I put a voltmeter on it a while back and it puts out 13.5~14V. Nothing to worry about.
My LS7 69 Camaro
Old 06-28-2007, 06:10 PM
thanks Scott
Old 06-28-2007, 07:18 PM
69Camaro's Avatar
69Camaro 69Camaro is offline
Yes, absolutely use a battery tender with EFI, just make sure you don't have the ignition on when you connect or disconnect it. I work for a GM Dealer and we have spent thousands of dollars replacing fried modules on vehicles that either had the battery go dead and were then jump started with the key on, or someone hooked up a battery charger with the key on. If the battery tender is hooked up with the ignition off, then you should be good to go. Get one that automatically monitors the voltage/charge and adjusts so that it doesn't overcharge.
1969 Camaro
Kore3 Z06 brakes
Hydratech hydroboost
Wilwood master
Ridetech stage 2 with truturn
Forgeline GA3 18x9.5/18x12.0
BFGoodrich Rivals 275/35 & 335/30
Magnum T56
Lots of AMD sheet metal
Sprinkled with DSE parts
Ididit Steering column
GM 376/525hp crate
Moser 12 bolt, tru-trac, 3.73:1
Speedhut Guages
Vintage Air
Corbeau LG1’s
Digi-tails
Ringbrothers
Harwood cowl
Old 06-28-2007, 09:11 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
We use the Ctek product on all cars that spend time at the shop, dead batteries suck...............
www.hotrodderjournal.com
Old 06-28-2007, 09:31 PM
lil427z's Avatar
lil427z lil427z is offline
yes.
rick k
