Old 06-29-2007, 12:48 AM
71OLDS's Avatar
71OLDS 71OLDS is offline
Default removable exhaust section/3 piece crossmember
I need to have access to my trans. Currently the crossmember and x pipe are in the way to easily "drop" the trans. Anyone running a 3 piece crossmember and/or removable section of the exhaust (x-pipe) on a 68-72 GM A body to allow this?
Here's my current:
Joe Lincoln
1971 Olds 442 Convertible & 1970 Cutlass Supreme
Old 06-29-2007, 11:06 AM
gearheads78's Avatar
gearheads78 gearheads78 is offline
I used Dr Gas ball cone collectors to build a drop out center like you are takling about once. Two sets gets expensive but it looked clean didn't leak and did not loose any performance.
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
Old 06-29-2007, 06:32 PM
71OLDS's Avatar
Thanks, I'll check 'em out. Anyone used/have a 3 piece crossmember?
Joe Lincoln
