Old 07-04-2007, 10:13 AM
Clockwork's Avatar
Clockwork Clockwork is offline
Default Road course setup advice/tips please
I posted on PT as well, but here goes.
I'm doing my first road course on Sat and need some advice on what I can do to set my 69' up.
I'm runnig QA1 coilovers up front with a Hotchkis sway bar, regular QA1 shocks out back with Hotchkis leafs and GW del a lum solid bushings.
17" wheels all around with BFG's, manual steering, Baer brakes and Speed Tech upper and lower control arms.
Questions...
What should I set the shocks to?
What psi in the tires?
Any other tips are also appreciated!
Dean
Old 07-04-2007, 02:51 PM
awr68's Avatar
awr68 awr68 is offline
Just wanted to say that if you don't have a RR oil pan you could be asking for trouble! Dan (conekiller13) lost a new crate 350 due to running a standard pan...yeah an expensive lesson!!
Tony
'68 Camaro
Old 07-04-2007, 04:42 PM
clill's Avatar
clill clill is offline
The big thing with a stock type oil pan is losing oil pressure in a extended turn. If you have a stock type pan I would put a extra quart of oil in. One quart should still leave you below the crank. If you have a oil pressure guage, pay attention to the pressure in a extended turn when you get a chance to glance at it.
Don't try to set any records, just get a feel for the car. If you can, ride with a instructor and have one ride with you. There are usually volunteer instructors to help newcomers. I remember my first track day, try to relax and have fun.
I have no idea on your shock or tire settings.
Old 07-04-2007, 05:28 PM
clill's Avatar
I assume you checked the car over for any loose nuts, belts etc, over flow bottle on the radiator, two throttle return springs. Torque your lugnuts and bring a torque wrench and retorque after a track session.
Old 07-04-2007, 06:18 PM
Clockwork's Avatar
Thanks guys
I have gone over the car and aside from not having an overflow bottle everything should be okay. I plan on taking it easy and just have fun for my first time out. There is another session in Sept, and if everything goes smooth on Sat I'll try a better my lap times then.
Dean
Old 07-04-2007, 09:52 PM
clill's Avatar
You will have a blast. I'm headed to Utah to Miller Motorsports Park this weekend for the Shelby convention. Maybe I can break something.
Old 07-05-2007, 07:16 AM
Clockwork's Avatar
Charley,
What car are you taking and What are you hoping to break? LOL!
Dean
Old 07-05-2007, 07:43 AM
clill's Avatar
Taking two Shelbys and a Mustang. I will be taking one Shelby and the Mustang on the track. Third one is just to display.
Old 07-06-2007, 12:10 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Where did you get the headlight covers?
They look great.
TY
