Old 07-09-2007, 05:44 AM
Default How can i get more "feel" in pwr steering?
I have stock C5 vette power steering pump and stock rack from grand am pontiac. Steering is quick and really good but maybe little bit too light. How can i get more feel on the steering ? Is there any pressure limiting valve in the pump or somethig?
63 Z06
Old 07-10-2007, 02:30 AM
Wake up!!!
63 Z06
Old 07-10-2007, 03:45 AM
ProTouring442's Avatar
Although there are companies that make pressure limiting regulators, I wouldn't reccomend them. The rack makes the "decision" on feel, so I would look into getting the rack recalibrated. If you just limit peak pressure, there will be times when you won't be able to get enough assist, like when parking, or when making a very quick steering input.
Shiny Side Up!
Bill
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 07-10-2007, 04:29 AM
Thanks Bill for the info.That was totally new to me.
63 Z06
Old 07-10-2007, 06:06 AM
XcYZ's Avatar
XcYZ XcYZ is offline
The amount of assist is based on a torsion bar in the steering. The softer the torsion bar, the softer the feel because more of the rotary valve is exposed and allows more assist from the pump. Changing the torsion bar to a stiffer one is the answer.
I know street rod shops make a PS regulator, but I have no idea how well they work, if at all and what issues they might cause with the system.
My LS7 69 Camaro
Old 07-10-2007, 06:43 AM
LL CUSTOM LL CUSTOM is offline
Cool
the preasure regulators sold by hiedts hot rods and such help adjust the amout of preasure going to the rack. they will have effect on the feel. but we use them mostly because a customer insist that he wants power steering and on a lite weight rod especialy one where the engine is place mostly behind the cross member. it can create an over responsive feel. in most case's on a street rod it is recomended to use a manual rack. which is what we usually start out with and if we think it justifies power we up grade. i am not sure that it will provide you with answer your looking for. perhaps if you contack flaming river or uni steer thier tech guy's can give you better answers. later larry www.llcustomperformance.com
