Old 07-12-2007, 05:09 AM
dqhemi dqhemi is offline
Default XV 5.7 and 6.1 HEMI Intake Manifolds
We've been trying to get these done for some time now, but the wait is finally over. Here's the details:
XV Motorsports has developed single plane intake manifolds to create serious horsepower with the 5.7 and 6.1 HEMI. Our manifolds were CAD designed, rapid proto-type tested and built to deliver maximum performance.
The manifolds feature a Holley 4150 mounting pattern, which will allow you to run a 4-BBL throttle body or carburetor with this manifold. The manifolds are being offered in either a carbureted or EFI version, with the EFI version machined to accept fuel injectors.
Factory manifolds were optimized to make power at factory levels. If you’re running a bigger cam, worked heads or have a stroker, you’ve only been seeing part of the power you could be making. Our manifolds are designed to flow much more airflow – the missing link to making big HP with the new HEMI engines!
Don’t want a cone filter under the hood? If you’re putting a new HEMI into an older vehicle or hot rod, this manifold will allow you to run carb style air cleaners, factory air cleaners, functional shaker hoods, etc.
We are also offering fuel rails to work with this manifold and 4-BBL EFI throttle bodies, as well as complete engine management systems.
This manifold is not suitable for use on pollution controlled motor vehicles and is intended only for racing and off-road applications.
Manifolds will be shipping in late August and we are accepting orders for them now.
Here's a link to these on our website:
Intakes and Rails
On this product we offer shop, dealer and wholesale pricing for those that qualify.
Here's some pics:
John Buscema
XV Motorsports
www.xvmotorsports.com
Old 07-12-2007, 06:16 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Very cool stuff, John.
What's that process called where you rapid prototype parts out of that solution and it comes out as a plastic/composite? I've seen it on TV and I've seen parts like that on display at SEMA.
My LS7 69 Camaro
Old 07-12-2007, 06:27 AM
wiedemab's Avatar
wiedemab wiedemab is offline
That looks like it was grown in an SLA machine.
Stereolithography
If my memory serves me correctly.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 07-12-2007, 07:21 AM
Stereolithography
Yes that's it - Stereo Lithography.
John Buscema
XV Motorsports
Old 07-12-2007, 08:02 AM
ZZ3ElCamino's Avatar
ZZ3ElCamino ZZ3ElCamino is offline
Rapid prototyping is the way to go! I use this technology with most everything I need to fit check with various designs. Missiles can be a pain to put together
Old 07-12-2007, 12:27 PM
You guys at XV are like oems !! Wery impressive work again. Could you pleeeeeese consider makeing parts for camaros too....
63 Z06
Old 07-12-2007, 03:59 PM
Hooligan's Avatar
Hooligan Hooligan is offline
So much cool stuff... so little money.
Old 07-13-2007, 05:54 AM
Thanks!
What kind of parts wold you like to see us do for Chevy's?
We're starting to look beyond just the Mopars so....
John Buscema
XV Motorsports
