Old 05-17-2005, 03:19 PM
jannes_z-28's Avatar
Default Tire pressure?
I would like to know your recommendations on tire pressure on big wheels like the ones I have, 275/40X17 & 245/45x17.
I think they are a little to stiff at the moment, I don't have any values now to compare with.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 05-18-2005, 07:26 AM
Clockwork's Avatar
Clockwork Clockwork is offline
Default Pressure
Good question. I would like to hear some input as well.
My BFG's (285/40/17)say max pressure is 44lbs. I have been running them at 40lbs. Positives/negatives?
Dean
Old 05-20-2005, 08:45 AM
Steve Chryssos's Avatar
Heck no. At 40 psi and up, they must be hard as rocks. I run 34 front 32 rear. The goal is to get some compliance back into the tires. Otherwise, it's grip, grip, grip....whoa doggie!! And I'm running 35 series 18's. Maybe try 2 psi higher than my settings for 17/40's Only drawback to dropping the pressure is that you have to check them more often. Try it, you'll be much happier with the ride and handling
Edit: Edited to insert "EEK" smiley.
________________
Steve Chryssos
Ridetech.com
