Old 05-25-2005, 04:33 PM
Derek69SS's Avatar
Default Low-Profile body mounts?
Does anyone make body mounts in either delrin or poly that are shorter, to lower my '69 Chevelle's body over the frame about 1/2"? I don't want solid, and I want it firmer than rubber.
Will it work? or will there be clearance issues with the floors somewhere?
With my LT1, I'll have way more hood clearance than I need, and i'm not afraid to hammer on my trans-tunnel. Valve-cover to Power-booster clearance should be OK, and I think I can adjust the front bumper brackets enough to line it up good. Anything I'm not thinking of?
Old 05-25-2005, 07:17 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Not sure with the Chevelle, but I know on a 1st Gen, the tranny will hit the tunnel for sure.
Why don't you want to go solid?
My LS7 69 Camaro
Old 05-25-2005, 07:34 PM
Derek69SS's Avatar
Have you driven I-90 lately?
I'm a little worried about NVH. I've never ridden in a car with solid. I'm going to have all solid spherical bearings in the rear, and delrin lower/ solid upper bushings in front... yet I want it to be a daily driveable.
Old 05-25-2005, 09:38 PM
Musclerodz's Avatar
Body bushings won't be an issue with everything else near solid.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 05-26-2005, 08:25 AM
Sandro's 1969 502 Camaro's Avatar
Sandro's 1969 502 Camaro Sandro's 1969 502 Camaro is offline
I'm running solid body mounts on my camaro and dosn't feel any different than my friends cars running polyurethane bushings.
Old 05-26-2005, 10:00 AM
61Bubbletop's Avatar
61Bubbletop 61Bubbletop is offline
Lateral-g Moderator
You may have issues with the header collector hitting the floors.....
