Old 05-26-2005, 10:58 AM
jy211's Avatar
jy211 jy211 is offline
Default Stock Camaro Rear End
I need to know what is the stock length of a 68' camaro rear end is. From backing plate to backing plate.
The one in my 68' is 54 1/2"....does that sound correct?
the numbers off the rear end 3969278NF...GM61 on the pumkin. Can anyone decifer this info?
Old 05-26-2005, 11:26 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Does this help?
Rear Housing Casting Date
Example: D141 - (D = Month, 14 = Day, 1 = Last digit of year (1971)).
Month: A = Jan, B = Feb, C = Mar, D = Apr, E = May, F = Jun G = July, H = Aug, I = Sep, J = Oct, K = Nov, L = Dec
My LS7 69 Camaro
Old 05-26-2005, 11:35 AM
jy211's Avatar
Thanks.
I am more concerned over the length than the numbers. Although, if I could decifer the numbers then I would know exactly what rear end is in my car...
Old 05-26-2005, 12:52 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
If a rear from a 69 Camaro is the same width, I will be happy to measure my old one for you.
Please be more specific on one point to what point you need measured.
Old 05-26-2005, 01:07 PM
jy211's Avatar
I need the measurement from backing plate to backing plate....
I know mine is not the original....so I may need to end up buying one from one of the board members...I just need to make sure the length is correct....
Old 05-29-2005, 05:36 AM
69MyWay's Avatar
Okay, the only way I was able to get this measured is from OUTER HUB face to OUTHER HUB face, in other words right againt where the drum slipped on and wheel bolts up.
This is exactly 60" from side to side. We added 2.5" on each side to the 9" for the Ford 9" conversion and C5 rear wheel offset.
Old 05-31-2005, 01:53 PM
jy211's Avatar
Thanks!
