Old 10-17-2007, 06:44 AM
COYBILT's Avatar
COYBILT COYBILT is offline
Default In need supplier that sells a 22MM metric Rod end
I need ot find a 22mm rod end that is teflon lined. Does anyone know of a supplier who would have this part? pegasus and HRP dont have them listed.
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
Old 10-17-2007, 12:05 PM
Scotch Scotch is offline
Something like this?
http://qa1.thomasnet.com/category/metric-rod-ends?
If they don't have it, they probably know who would.
Good Luck!
~SP~
Old 10-17-2007, 01:17 PM
rwhite692's Avatar
Did you already check here?
http://www.mcmaster.com/
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 10-17-2007, 04:54 PM
COYBILT's Avatar
I found a place called maryland metric that had a 22mm rod end. It is a rather large size to say the least.
Old 10-17-2007, 07:27 PM
Fluid Power's Avatar
My company is a dealer for FK Rod ends but man, 22mm is odd ball to say the least. I had some 20mm but not 22. What is it going on? I can honestly say I have not seen one of those.
Darren
Old 10-18-2007, 02:02 PM
jannes_z-28's Avatar
22 mm is very close to 7/8 inch (22.2 mm)
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 10-18-2007, 02:38 PM
Check these guys.
Tyler
Old 10-18-2007, 04:02 PM
COYBILT's Avatar
Im using them as a carrier on my steering shaft. I am running aircraft/ mil spec u joints on the car. The OD on the joints is .866 or 22mm exactly, I found them and its the only metric part I want to use on the car.
