Old 10-28-2007, 02:29 PM
deuce_454's Avatar
Default boost??
Ok here is the setup... stock 2002 LS1
i dont want to open the engine yet... so please no crank, heads, piston and rod suggestions... i am windering what boost i can safely run on an stock LS1 on 98 octane (ninety-eight) i have a large intercooler
and what power should i expect (buy injectors to feed)
and lastly... will this fit under a g-body hood???
Jake: Hit it.
Old 10-28-2007, 02:31 PM
deuce_454's Avatar
another pic of the height.... i am prety worried about hood clearance..
Jake: Hit it.
Old 10-28-2007, 02:37 PM
camcojb camcojb is offline
10-12 psi is the most I've seen last assuming no detonation. The octane certainly helps as well as a good efficient intercooler and a proper tune.
Old 10-28-2007, 03:19 PM
deuce_454's Avatar
a stock LS1 makes what 325 Hp, so at 12 pounds that comes out at about 590 Hp with no cats ans A/C correct???
Jake: Hit it.
Old 10-28-2007, 05:11 PM
I've seen the stock GTO's at 350 hp come in at 525-550 rwhp with a good twin turbo kit, stock engine.
Old 11-09-2007, 03:58 PM
deuce_454's Avatar
just talked to the DOT inspection guys and there is NO way i can swap in a different engine and modify it... so i guell ill sell the setup (any takers??) and do a head, cam and claim itīs stock...
Jake: Hit it.
Old 11-09-2007, 05:31 PM
stick the turbo setup in the for sale section, it'll go fast.
