Old 11-13-2007, 08:32 PM
aany001's Avatar
aany001 aany001 is offline
Default 350 Vortec (engine code R) mods
I will be putting a 97 350 vortec in my car and was wondering if anyone has some tricks up their sleeves to crank up the ponies.I will be using a carb and installing an LT1 6spd behind it.Any suggestions would be welcome.
thanks
Steve
Old 12-08-2007, 07:01 AM
aany001's Avatar
anyone??
Old 12-08-2007, 07:53 AM
AllSpeedAndy AllSpeedAndy is offline
383ci's, 9.0.1 comp, and put a procharger on it
Edelbrock makes a nice E-tec head for the vortec stuff and eagle makes everything you'll need for the bottm end and pistons are easy, Je has those to.
Old 12-08-2007, 07:59 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Stroker crank, different cam, rpm intake...
Tons of vortec builds on the internet.
Old 12-10-2007, 08:13 PM
aany001's Avatar
thanks for all the info guys
Old 12-11-2007, 06:23 PM
bmxmann bmxmann is offline
http://www.nastyz28.com/forum/showthread.php?t=56505
That thread has alot of useful info!
Old 01-20-2008, 07:50 PM
Repo Man Repo Man is offline
Take a look at this link, http://www.chevyhiperformance.com/te...ams/index.html
I have one of these with very low miles, and I'm planning on building it pretty much like the one in that article. My present 406 is worn out, so I'll throw one of these together while I decide on building a better 406, or moving on to an LS based engine.
Unfortunately, L31 blocks are not machined for mechanical fuel pumps, so you'll need to set up an electric one if you haven't already.
Old 01-21-2008, 07:50 AM
woody80z28's Avatar
woody80z28 woody80z28 is offline
I have an older engine block with a 280H flat tappet cam at 10.5:1 with vortec heads and an airgap and I can vouch that it works well. I also have an LT1-style 6spd behind it and hills still aren't a problem in 6th thanks to the vortecs. Truck heads are nice for the low-mid range grunt.
