Old 11-15-2007, 08:12 AM
AB69Z AB69Z is offline
Default 69 Camaro
new to this site and looking forward to getting the info I need in helping me with my build. First question I have is I have an RS car that my plans are to put a LS7 into is the possible with an RS?
Old 11-15-2007, 08:22 AM
907rs's Avatar
907rs 907rs is offline
I missed your question. Are you asking if it's possible to install an Ls7 into a first gen RS? If so, absolutely!
..And welcome.
Bill
Old 11-15-2007, 08:37 AM
Default 69 rs
sorry should I should have been more specific. would the location of the remote oil reservoir tank for the dry sump system be a problem for any of the RS components
Old 11-15-2007, 08:39 AM
907rs's Avatar
Most of the cars I've seen mount the tank to the inside of the core support, so it shouldn't be a problem.
Bill
Old 11-15-2007, 08:46 AM
Default 69 rs
Thanks for the info. this a great site with a lot of great people really looking forward to getting into this build
907rs's Avatar
After looking at a few pictures, the tank may interfere with the actuators below the inner fender. (if you use the stock RS set up)
Maybe someone else that's done it will chime in.
Bill
Old 11-15-2007, 10:23 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Welcome.
If you plan on running the dry sump tank where everyone else does, where the battery normally goes, then like Bill said, it won't work, the factory RS linkage will be in the way. However, I don't know how much room and/or changes to the linkages are made when using Detroit Speed's electric motor kit. I haven't used the DSE electric RS motor kit, so I don't know changes, if any, are made to the door mechanism arms.
I noticed on the Richard Childress Series 3 69 Camaro that has a Childress SB2, the dry sump tank was mounted in front of the core support. That would be an option if you had fitment issues.
My LS7 69 Camaro
Old 11-15-2007, 10:52 AM
Default 69rs
thanks for the help and i got to say I've spent a lot of time looking at the pics of your car.....WOW
