Old 12-03-2007, 04:51 PM
freebird freebird is offline
Default Art Morrison 4 tri bar
How does this kit compare to the alston tr bar and DSE 4 link?
I havent heard alot of info on them.
thanks
Dave
Old 12-06-2007, 07:07 AM
Silver69Camaro Silver69Camaro is offline
Since nobody bit on this, I'll add my two cents.
I'm not sure if it really does compare with Alston's or DSE's setups. I say that because their designs fit the stock frame rails, while ours is an entire replacement rear clip for those willing to remove the stock trunk. Perhaps this will change in the future. Anyway, they are very different products.
It is a proven design, as seen in Art's '55 Chev and '60 Vette, as well as others.
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
Old 12-06-2007, 07:46 AM
Well this is were i am at.
i have a 67 camaro that needs a complete floor and trunk. I am putting DSE wheel tubs. So i purchased a set of 21st century frame rails knowing that i will most likely have to cut out a section of the trunk floor. I have been debating on a fuel cell instead of a stock fuel tank.
So i guess my point is, since i am moving the frame rails, i will have to modify any kit that i go with. But the A.M. suspension seems to be less modification to fit in. My question was based on performance.
Old 12-06-2007, 01:41 PM
That's tough to compare. I'm not sure if you'll find any hard data to make the decision easy.
Matt Jones
Mechanical Engineer
