wtb: t56
12-15-2007, 06:46 PM
khoult
wtb: t56
i am looking for a clutch master and slave cylinder for my lt1/t56 swap in a 69 camaro.
khoult
Find all posts by khoult
2
12-15-2007, 07:16 PM
68protouring454
go to gm, get both with line pre bled, as cheap or cheaper then napa or others, bolt on and go
last i knew they were around 170
Jake's Rod Shop
68protouring454
Find all posts by 68protouring454
3
12-16-2007, 09:02 AM
khoult
what's the difference between a gm or ats set up?
khoult
4
12-16-2007, 12:26 PM
68protouring454
i believe they cut off the non adjustable eyelette that it comes with from gm, then thread it and use a heim end so its adjustable, it is very important not to over throw the master, i believe the pedal throw should be 15/16 or so
Jake's Rod Shop
68protouring454
Linear Mode
Switch to Threaded Mode
09:49 AM
