Old 12-16-2007, 11:58 AM
Musclerodz's Avatar
Default New Twist Machine product! Prostyle shift sticks
Musclerodz is proud to introduce the newest product from Twist Machine and has received the first pieces available to the public! Any of you that already has Twist Machine parts already know the quality of their products. I feel honored to be chosen to make this press release below. Thanks Steve!
Here’s the latest addition to Twist Machine’s ProStyle™ line of
billet accessories. Introducing “Reach Adjustable” shifter sticks
for manual transmissions. The design improves ergonomics and adds a
unique style. Mount the stick in any of five fore/aft positions using
the included inserts. Fine tuning shifter ball placement will help
ensure that you never miss another shift! Furthermore, the
adjustability may help you gain clearance to consoles. Shifter to
console clearance is a common problem with today’s popular
transmission swaps. ProStyle™ Shifter Sticks fit all factory and
aftermarket stub style manual transmission shifters with .875”-.
900” bolt spacing.
CNC machined from 6061-T6 aluminum, ProStyle™ Shifter Sticks are
styled to match Twist Machine’s other billet accessories such as
core support bars, cowl induction trim plates, and more. Used
together, these parts help you carry a distinctive ball mill and
slotted styling theme throughout your car. More matching accessories
are under development.
ProStyle™ reach adjustable shifter sticks come with 3/8”, 8mm and
10mm hardware plus two multi position inserts.
Non-adjustable versions are also available for use with Hurst
Competition style shifters that have “U” shaped stubs. Choose 8”
straight or 10” bent. Pricing is $115 (straight) and $130 (bent).
Don’t settle for stock, ill-fitting shifter sticks. ProStyle™
sticks look awesome, and work great.
Link to pix:
http://web.mac.com/streetfytr/iWeb/T...LC/Sticks.html
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-20-2007, 09:01 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Will it work with a T56?
Old 12-20-2007, 09:14 AM
Musclerodz's Avatar
Yes, T-56, T-5, TKO, Muncie. Most all trannies that use a bolt on shifter.
Mike
Mike Redpath
facebook page
Old 12-20-2007, 10:31 AM
monza's Avatar
monza monza is offline
Any better pics even better any mounted into cars? Was Devious rocking one of these at SEMA?
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 12-20-2007, 02:20 PM
Musclerodz's Avatar
Here are some pics from the webpage some can't view for some odd reason.
Mike Redpath
facebook page
Old 12-20-2007, 02:24 PM
jimhamptons's Avatar
jimhamptons jimhamptons is offline
FYI, I am the hand model in those pics. Hot!
Old 12-20-2007, 04:00 PM
Steve Chryssos's Avatar
We built these sticks for the following reasons:
Ergonomics Part 1: Mulvey's 69 pace car (shown in the photos) has a T56 which came with a 4th gen "dogleg style" shifter. The front/rear offset to this stick placed second gear very close to the middle of the driver's thigh (The shifter is up his ass we often joked) The original plan was to just build a straight stick. Then the reach adjustable feature came to mind as a means of letting the driver fine tune stick position for the best possible reach in all gears. Different driver/seat/transmission combinations demand more than just one stick position.
Ergonomics Part 2: The Shifter ball was inspired by the split ball design on the 2009 Camaro Concept. From there, we tried an elongated version that feels incredible. It fits snugly in the area created by the heel of your hand and the back side of the knuckles on your two middle fingers. Once you row your first gear with this ball design, you will be hooked.
Console Clearance: In addition to the reach adjustable feature, the bent stick version features a longer bottom section that helps clear factory consoles when used in conjunction with a modern 5 and 6 speed overdrive transmission swaps.
Strength: Sticks are machined from 6061-T6 aluminum. Black oxide coated socket head cap screws are included in three sizes: 3/8", 8mm and 10mm
Style: Last but not least, the shifter sticks are a perfect match for our other available ProStyle™ accessories such as core support bars. More accessories will be added shortly to help you carry a common styling theme throughout your modern muscle car. Next up are gauge rings. Slick little pieces that snap over most Auto Meter gauges and share the ProStyle™ theme.
There you have it. A simple, often overlooked part that has been hyper-engineered into a cool looking, functional solution. We're having fun designing and producing this stuff. I hope you all enjoy it. Thanks for looking.
/Steevo
________________
Steve Chryssos
Ridetech.com
Old 12-20-2007, 04:02 PM
Next time, shave your knuckles.
________________
Steve Chryssos
Ridetech.com
Old 12-20-2007, 06:13 PM
MarkM66's Avatar
Mike
My memory may be fuzzy, but I thougt a T56 shifter was one piece.
Old 12-20-2007, 09:41 PM
That looks like a B&M. It's a one piece and therefore our stick won't fit. Pretty much one of the few one piece sticks available. Most are stub style.
________________
Steve Chryssos
Ridetech.com
