Old 12-18-2007, 06:03 PM
01somta 01somta is offline
Default Primer after blasting
I'm picking up my car tomorrow after getting blasted. The guy that is going to prime had me pickup the primer and activator tonight. The primer is 2k acrylic urethane, would this be ok on bare metal and hold up for a year or two until I get the paint and bodywork done? Thanks for the help.
Dustin
Old 12-18-2007, 06:40 PM
deuce32's Avatar
deuce32 deuce32 is offline
i use epoxy urethane from ppg myself it seals it as well
Old 12-18-2007, 07:28 PM
would the 2k acrylic urethane be ok on bare metal?
Old 12-19-2007, 05:01 AM
wiedemab's Avatar
wiedemab wiedemab is offline
We normally use Dupont Vari-Prime on bare metal. It's pretty good stuff, bad nasty so wear a respirator.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 12-19-2007, 06:22 AM
comp-spec's Avatar
PPG DP primer or a self etch primer 2K primer is to go on after one of these
Old 12-19-2007, 08:35 AM
Musclerodz's Avatar
If the surface is smooth and doesn't need sanded, we phosphate treat the metal to kill any rust left, then use etch-prime or DTM epoxy before 2K urethane primer.
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-19-2007, 07:55 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Dustin
Dustin:
That doesn't sound like a good idea, your supposed to get, "Blasted", AFTER you've picked up your car.
Ty
Old 12-19-2007, 08:08 PM
tellyv's Avatar
tellyv tellyv is offline
use a good epoxy primer only, nothing works better, 2k is not ment for rust defending it is for build only, vari prime is ok but epoxy is the best.
Old 12-20-2007, 05:58 AM
Dustin
So it's going to sit for a year or 2? What kind of conditions is it going to be sitting in - outside, inside, climate controlled, etc?
Jeff Allen
J2 Speed and Custom
Old 12-20-2007, 09:37 AM
PRRC PRRC is offline
I would like to give you a heads up about soda blasting, You will need to wash down the car with vinegar and water as soon as you get it back to remove a the soda from the metal. If you don't you will have adhesion problems down the road. We wash them down then 80 DA all the panels before we epoxy prime.
www.paradise-road.com
