Old 06-28-2005, 08:28 PM
Richz68 Richz68 is offline
Default Budget rear disk with a 9"...?
I was planning on using a 8.5" 10 bolt for my car ('68 Camaro), but I ran across a 9" that is the correct width for me with my positive offset C5 wheels.
I was planning on running the '93-97 F-Body rear disc set up on the 10 bolt which is a direct bolt on upgrade for any 10 or 12 bolt rear end. I know that the brackets will not match the 9" ends.
Before anyone tells me to call Willwood, Baer, Currie, Strange and buy their system remember that I want a budget set up if there is one out there for the 9" rear.
Thanks for any help!
Old 06-29-2005, 03:20 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
I am running 98-2002 F body disc on my 9" in a first gen camaro. My axle guy welded a flange on the axle that directly adapted it to allow the GM housing to bolt on. I am running C5 rear rims with no adapters.
Totally budget and looks/works great.
Here is a pic of the first rough fit of the axle to the car.
NOTE-the LS1 4th gen brakes are 12" and they use the mini drum brake for the parking brake system.
Old 06-29-2005, 06:53 AM
sinned's Avatar
sinned sinned is offline
Ford Explorer rear discs bolt up with almost no modifications. Of course they are the wrong bolt circle so you need to re-drill the wheels. I think even to buy all the stuff new is only 400.00. A wrecking yard package should come in under 250.00.
Dennis
Old 06-29-2005, 04:32 PM
Chris,
I sent you an email for more details soncerningt the measurements of your differential. I am using Stock C5 wheels too on my '68 so the measurements would be invaluable concerning wheel/tire fitment in the stock wheel houses.
Thanks a million!
Rich
Old 06-30-2005, 03:55 AM
69MyWay's Avatar
No worries.
Just for the record you need to add 2.5" to each side of your stock length (this is to the hub/disc face where the tire bolts on) to achieve the correct C5 rear wheel offset.
On a 69 Camaro you will also have to trim a tad in the wheel house lip to avoid rubbing.
Old 06-30-2005, 02:29 PM
spaztikatik spaztikatik is offline
just thought i'd let you know, i have a completely new explorer disc brake set up on my currie 9" rear that havent been used. they have the correct bolt pattern and everything from currie, 4.75x5 for A-bodies, but since i am switching to baer brakes i'll let you have them for 150
if youre interested, give a shout, im more than willing to help out
-Russ
Old 06-30-2005, 04:36 PM
$150.00 hmm I'm interested, but I need to make sure that the diff has the correct axles for clearence of the kit.
You have a PM!
