Old 01-06-2008, 04:15 AM
BigVin BigVin is offline
Default Calling Steve Rupp
Steve
How did you mount your Safecraft fire extinguisher on your seat track? Did you use Safecraft seat bracket or did you fab your own? If you fabbed your own pics
would be helpfull. Also how hard is it to adj seat and is it comfortable for passenger.
Thanks Vin
Old 01-07-2008, 12:21 PM
Steve1968LS2's Avatar
Originally Posted by BigVin
Steve
Thanks Vin
Sorry for the delay but I've been laid up with a cold..
I made a cardboard template for a plate and took that to my water-jet cutter. The plate bolts to the two front seat bracket bolts and has a 3x4" tab on it.
I then bolted the Safecraft extinguisher to that tab. Oh, I bent the tap on a brake to get the right angle. I will try to take some pics in the next couple of days. I want to revise the design and have that water jet guy cut out a few new ones. He will then have the design on file and anyone can call and get one cut out.
It is not in the way of the passenger at all, easy to adjust the seat.
Steven
Old 01-07-2008, 01:16 PM
Thanks Steve hope you feel better. This winter all my upgrades have been for safety. One is a fire extinguisher that I can reach and not the one in the trunk. Yours is mounted in a great spot and I would like to do the same thing.
Thanks Vin
Old 01-07-2008, 04:02 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Hey Steve, you have an excellent idea.
I think Goodies Speed Shop was just having a sale on extinguishers, too.
My LS7 69 Camaro
Old 01-12-2008, 01:24 PM
Here it is. It's just plate alum I had cut to a template at my water jetter. I then drilled the hole and rounded the edges. After that I attached the plate for the Safecraft extinguisher. Oh the "tongue" is offset one inch and was bent down towards the floor just a bit.
I'm going to fine tune the design and then anyone can call my cutter and have a few churned out.
Old 01-14-2008, 01:29 PM
Steve
Thanks for the pic bluilding one right now.
Vin
Old 01-14-2008, 01:33 PM
Steve
Vin
Depending on your extinguisher you can offset the tounge either way so that it mounts in the middle of the seat (for looks).
Post pics when your's is done. It's a real handy place to mount the extinguisher.
Old 01-14-2008, 07:11 PM
XcYZ's Avatar
I sure like that, Steve.
My LS7 69 Camaro
Old 01-14-2008, 08:28 PM
Yea, and only cost maybe $10 to make.. depending on the what lever you have for your seats you could even suck it in closer to the seat. My final design will be 1/4 inch closer to the seat and slightly more offset.
Old 10-14-2008, 07:31 PM
Datsbad's Avatar
Datsbad Datsbad is offline
steve post up a pic of this again
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
