Old 01-06-2008, 03:36 PM
Flash68's Avatar
Flash68 Flash68 is offline
Default Low back seats, roll cage, and harness?
I have already purchased the ISS seats for my Camaro and really like them and their shape. But I also am coming up to a point where I need to decide if we are going to do a roll cage or not. I would like to do one for obvious safety reasons, but I am under the impression that by using the low back ISS seats, I have no way to tie in a good 5 point harness as I would be if I had one of the high back racing seats with the harness inserts to tie in the cross bar of the cage.
So, does anyone know of a safe and nice looking setup to use with low back seats and a roll cage? Does the only way to do this right involve ditching these seats?
(attached pic of what I believe are the same ISS seats I have - if not, they are roughly same dimensions. Thanks to Bob the Camaro)
Thanks.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 01-07-2008, 05:07 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I know Rad Rides "Chicayne" used a bench, cage and shoulder straps.
I can't seem to find any pictures of that area though.
Old 01-07-2008, 05:15 PM
novanutcase's Avatar
Only interior pic I have of chicane of that area!
John
Old 01-07-2008, 05:48 PM
Yes those are ISS seats, that Tracy reworked "ALOT"!
If I remember correctly Chicayne has some "airplane" belt system in it. They retract via a lever on the console.
Jeff Allen
J2 Speed and Custom
Old 01-07-2008, 08:45 PM
Flash68's Avatar
Hmm... if it is indeed tied into the cage cross bar wouldn't that create some wicked whiplash to the neck upon collision due to the low back??
"Bob" doesn't have a cage does he?
thanks guys
2014 4 tap Keezer
Old 01-14-2008, 10:23 AM
JayR JayR is offline
Lateral-G Supporting Vendor
You'll get whiplash if you get nailed without headrests regardless of harnesses or a cage but it doesn't seem like the lowbacks would make it hard to use the belts if you have them snugged.
If you're trying to be legal for track days, I would suggest making a headrest that can be bolted onto the cross bar, then remove for regular use.
Old 01-14-2008, 11:01 AM
Flash68's Avatar
Thanks Jason. I am actually not concerned with the track legality as I don't plan to go there much, if at all. I am really just trying to make it as safe as possible on the street for me. And I just don't want to get rid of these seats as I don't like most of the tall back seats avail on the market.
2014 4 tap Keezer
