Old 12-09-2004, 03:52 PM
rwhite692's Avatar
Default RWHITE692's 69 Camaro Project
Ok Scott here goes:
My gold car is (was) an original LM1 car, 255HP 350 with a powerglide and the original open 12-bolt rearend. I purchased it in Southern Ca in August 2002, from a gentleman who had owned it for over 20 years and was using it all of that time as his daily driver. It had received one repaint sometime around 1980, in the original Olympic Gold. It still has it's CA black/yellow plates issued in 1968. (My other car has the 9TYN6T9 plates)
I removed the original 350 and set it aside, and built a roller cammed 383 stroker for it, with a stout bottom end and a set of TFS Aluminum heads, with a pretty tame carbureted induction setup with a 150HP N2O plate. It probably makes somewhere around 450HP (sans N2O). I converted the car to MT and installed an LT1 style T56, with guidance from Marlan Davis' CC article, farming out only the driveshaft cut and re-balance. The clutch is a centerforce dual friction setup with a McLeod actuator cylinder. I built the trans crossmember from a TH400 unit, and it looks like GM made it.
The brake system is C5 corvette front disc, LS1 rear disc, with hydroboost assist. Suspension mods are simple, Hotchkis 2" drop springs up front, upper arms relocated via the Guldstrand mod, Energy Suspension bushings, 1.125" hotchkis sway bar. Out back are DSE 3" drop leafs. Shocks are edelbrock up front and KYB out back (for now). Speedtech supplied the solid body mounts, and the front spindle brackets for the C5 calipers. I rebuilt the rearend with a powertrax unit and 3.89 R+P.
Wheels are Boyds, variation on "Dictator", FRONT: 18"x8" with 4.75" BS, REAR: 18"x9" with 5.5" BS. Tires are 245/40R18 Front, 275/40R18 rear.
The idea on this car was to keep it at very least semi-driveable, all of the way through the project mechanically, and then when basically satisfied with the mechanical modifications for the most part, blow it apart for paint. Currently I am in the middle of RS front conversion with original Endura bumper. Having done this before, everything will be fitted and then disassembled for paint. I drive the car occasionally to work (60 miles one way) and It's a blast. Gotta do something about the headliner soon though, before it comes off and wraps around my head at 80MPH...
Just want to thank you Scott for providing this place for us to hang out and exchange ideas, and for being a first-class guy supporting the hobby...
Rob
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 12-09-2004, 03:55 PM
jonny51 jonny51 is offline
Looks good Rob,drive it up when you come get your parts for the other car
Old 12-09-2004, 05:08 PM
slck6t9's Avatar
slck6t9 slck6t9 is offline
Rob your car looks great. Are you going to go back with the gold color?
Old 12-09-2004, 05:22 PM
rwhite692's Avatar
Thanks guys- The plan (for now...could change) is to paint the car a custom mixed blue color, it is a very bright medium metallic blue that really "pops". Still playing around with it...I'm undecided as to wether the car will get stripes (Z/28 "band-aid" stripes, D90 hockeystick stripe, or none)...any inputs welcome!!
My Lateral-G Page
My Shop Build:
Old 12-09-2004, 05:32 PM
rwhite692's Avatar
Hey Jonny I would, but we will be going up to Petaluma for Holiday visits etc and my wife (who is very tolerant) is unfortunately not tolerant enough to sit through and appreciate the wonderful sensory experience of riding in a first gen with a healthy small block and no interior in it whatsoever...for a ~2 hr. drive... ...Some people just don't know how to have fun!
My Lateral-G Page
My Shop Build:
Old 12-09-2004, 05:38 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Awesome, Rob! Glad to see you posting your project here. You should post a pic of your master cylinder fittings. I think it's trick!
My LS7 69 Camaro
Old 12-10-2004, 09:23 AM
mdprovee's Avatar
mdprovee mdprovee is offline
Very nice car Rob. I really like those wheels.
MIke
Old 12-10-2004, 12:50 PM
67Sally's Avatar
67Sally 67Sally is offline
Great car Rob.
William Rouleau
Project PonySnake
Old 12-11-2004, 07:39 AM
hotwheels's Avatar
hotwheels hotwheels is offline
beautiful car man..............hotwheels
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
Old 12-11-2004, 01:32 PM
907rs's Avatar
907rs 907rs is offline
Really nice car Rob!
I too like those rims, mine are Budnik Fontanas, very similar.
Bill
