Old 01-25-2008, 12:41 AM
latzoo latzoo is offline
Default 67 Camaro chassis info
If I use a Chris Alston complete subframe package, do I require a modified oil pan for the 99LS1 that I have purchased for my 67 camaro.. As of right now I do rrequire this modified oil pan without the new subframe..
Old 01-25-2008, 06:23 AM
XcYZ's Avatar
XcYZ XcYZ is offline
No idea. What did Chassisworks say when you asked them about fitting an LS1?
My LS7 69 Camaro
Old 01-27-2008, 11:39 PM
crazycarl's Avatar
crazycarl crazycarl is offline
Yes, you need to run a non-stock pan. Moroso or Milodon (I always get them mixed up) makes one that will give you good capacity and plenty of clearance. You will have to either switch sumps or modify the tube as well. However, if you have it in your stock subframe, any modifications that you've made will most LIKELY fit. The Chassisworks SF has more clearance than stock, but not THAT much more.
I'm probably just screwing with you, so please don't take it personal.
Old 09-04-2009, 12:37 PM
67camaro6spd 67camaro6spd is offline
Default you must chop '98-02 camaro pan to clear xmember
you must chop '98-02 camaro pan to clear xmember. I have exact setup you are starting to build. i went with s and p to chop pan ...~$269 you supply pan.
Old 09-04-2009, 04:28 PM
youthpastor's Avatar
Default Look To Your Left
http://www.autokraft.org/
sponsor here at Lat-G - great product!!
