Old 07-07-2005, 09:27 PM
Blown353 Blown353 is offline
Default So my car went and beat up a '69 Camaro...
...and took its lunch money and its front spoiler.
Yea or Nea?
Troy
1969 Chevelle
Old 07-07-2005, 11:44 PM
907rs's Avatar
907rs 907rs is offline
It's kinda hard to tell from the angle of the pic Troy, but it looks like it could use a little more width and height.
Weren't you talking about doing one fabbed up out of aluminum a while back?
Bill
Old 07-08-2005, 06:14 AM
BC69's Avatar
BC69 BC69 is offline
Get us some more pics, but it seems to be a bit small in this application, just doesnt seem to be proportional. But get us some more pics and maybe itll shine some better light.
Better watch out, that 69 Camaro could come back with some friends.
Tim
In memory of those gone before us
In gratitude for those who care.
Old 07-08-2005, 07:06 AM
I agree it could use more width and height to be more effective. But this one was a freebie, so I decided what the heck and made some brackets. I don't have any pressure transducers to stick under the hood or other methods to measure front end lift, but it does seem to have helped a little bit. It's also very effective at stopping bugs from comitting suicide all over my crank pulley, sway bar, steering box end cap, and A-arms. Makes for much easier clean up after a drive out on country roads near dark, just wipe 'em off the spoiler.
One advantage to the Camaro piece is that if I ever subject it to a curb bashing in the future (hope not!) it's only $18 and very little work to replace (needs minor trimming in the center.) If I were to tag a hand-made aluminum spoiler against a curb, I'd be really ticked!
I'm still planning on bending up an aluminum spoiler in the same basic shape as this Camaro piece, only going about a foot wider and maybe 3-4" lower. This one works for now.
Troy
1969 Chevelle
Old 07-14-2005, 06:12 AM
69boo307 69boo307 is offline
I want a front air splitter for my car, I thought about using this one:
http://www.yearone.com/serverfiles/p...hid=220AB58139
It's for a 70 Buick GSX, and should be a direct bolt on for a chevelle and fit very well. The GSX was VERY similar to the chevelle and used the same frame, so it should have the same mounting points.
Old 07-14-2005, 08:23 AM
MrAngry's Avatar
MrAngry MrAngry is offline
I actually have one on my 68' Charger and it really worked out perfectly... fits perfectly between the marker lights and really smooths out the front of the car. I think for this to work the stance of the car really has to be dead on.
MrAngry
Old 07-14-2005, 09:50 AM
69rs's Avatar
69rs 69rs is offline
Those Chevelles are bullies! Actually the Camaro probably offered the spoiler as a bribe so the Chevelle would quit crying about not being as pretty as a Camaro!
Can you adjust it so it's not quite as flat? Other than that it looks good.
Old 07-14-2005, 10:02 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Mr. Angry, that's a beautiful Charger.
My LS7 69 Camaro
Old 07-14-2005, 11:37 AM
USAZR1's Avatar
USAZR1 USAZR1 is offline
Troy,check out the spoiler on my car's rendition done by Brian Cichocki. Just click on the link in my sig. However,my car is so low that I worry more about hitting my front bumper.
Clint Hooper
Clint's 70 El Camino restomod Sold
Clint's 69 Elky Protourer Sold
Old 07-14-2005, 11:48 AM
MrAngry's Avatar
Sorry to off topic here but, USAZR1 - what wheels are those - the look PERFECT on your truck.
